Any particular brands of AGM batteries to avoid? - SailNet Community
 7Likes
post #1 of 31 Old 05-17-2019 Thread Starter
After a week of research and so forth and so on ... I've come to the conclusion that I need to replace my batteries and that I want to install AGMs.
As many of you know, that decision doesn't end the decision making.
Now I have to figure out what brand of AGMs to buy. West Marine is currently having a sale that is very appealing. Despite the general "people hate West Marine" sentiment, I haven't been able to find any information about their branded AGM batteries being good or bad.
Beyond that, there are only 5 jillion brands of AGMs available, and the prices vary quite a bit. My searches across the Intertubes haven't turned up any useful comparisons between brands, so I'm tempted to go for the less expensive choices (first in line is West Marine at this point) but I don't want to screw myself if the cheap batteries are garbagy.
Does anyone know of any resources online that have qualitatively tested AGM brands? Any specific brands to avoid? Any feedback at all would be interesting to read at this point.
BillMoran is offline
post #2 of 31 Old 05-17-2019
Re: Any particular brands of AGM batteries to avoid?
It will be harder than you think. Most batteries are just rebranded versions from the same factory. In the case of WM, I believe most (maybe not all) of their AGMs are from East Penn, which is a quality manufacturer. In any event, the source is what you need to know, not the retailer.
If you are switching chemistries, be sure you switch charging profiles too. AGMs are good technology, as they can't leak and will accept a ton of charge, pretty quickly. That's an advantage, when charging via a generator or high capacity alternator. On the other hand, they can burn out an alternator, if it isn't properly temperature limited. Most stock alts are not. AGMs also want to return to 100% state of charge frequently for longevity. If you oversize the bank, you can get away with age degradation longer, but that's expensive too.
SanderO and mbianka like this.
Jeanneau 54DS
Minnewaska is offline
The Following User Says Thank You to Minnewaska For This Useful Post:
BillMoran (05-17-2019)
post #3 of 31 Old 05-17-2019
Super Moderator
Maine Sail's Avatar
AGM brands we recommend to our customers, based on thousands of hours of testing (each capacity test takes 20 hours), and real world use/abuse by our customers. In order of preference:
Firefly Carbon Foam
Odyssey TPPL AGM
Northstar TPPL AGM
Lifeline AGM
Full River or Rolls AGM
Not all AGM batteries are created equal and there is a ton of junk out there. East Penn makes terrific GEL batteries, some of the longest lasting batteries going, but I'd not install their AGM product on Kim Jong-un's boat...
capta and flyrod like this.
______
-Maine Sail / CS-36T
Maine Sail is offline
The Following User Says Thank You to Maine Sail For This Useful Post:
post #4 of 31 Old 05-17-2019
?......Not all AGM batteries are created equal and there is a ton of junk out there. East Penn makes terrific GEL batteries, some of the longest lasting batteries going, but I'd not install their AGM product on Kim Jong-un's boat...
Iíd take @Maine Sail word for it. Politics and all.
Iíve used WMís AGMs for my dedicated electric winch bank, with no ill results. However, that is very different from a house bank.
Jeanneau 54DS
post #5 of 31 Old 05-17-2019 Thread Starter
I'm working on finding replacement charging hardware. It's frustrating that everything seems to be overbuilt and I'm not a fan of paying for a lot of stuff I won't use ... for example, why do so many of the shore power chargers have 3 bank capacity? How many people actually have 3 separate battery banks? Space constraints are also driving me to avoid buying something larger than necessary. Any recommendations on shore power chargers?
post #6 of 31 Old 05-17-2019
chef2sail's Avatar
We have 6 - 6 volt lifelines
There Are reasons you pay a premium for them and ways to compare them
1 - warranty
2- ability to condition them. Only AGM which encourages that. Itís a necessity for wet cells. I believe it why mine lasted over 10 years both times
3 - footprint- theses have smaller heights
4- number of deep cycles to be expected
Like Minnie said match alternator or you work it to death.
All AGM are not the same
West marine are not great quality IMHO
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
ďSailing is just the bottom line, like adding up the score in bridge. My real interest is in the tremendous game of life.Ē- Dennis Conner
chef2sail is online now
post #7 of 31 Old 05-17-2019
Yes follow MS' reco, in NA market those are the ones to give you longevity.
If you only want them to last a season then others will do fine.
____
Good chargers are expensive, multiple outputs is not the reason.
Can easily pay as much as for the bank, but the charger will last longer.
ProMariner Pronautic P series
shares the same motherboard with the
Sterling ProCharge Ultra
Both are great, and the user-custom setpoints are great for future proofing.
Victron, Magnum, MasterVolt are also top-notch but pricey.
From the RV world, might be cheaper, but prolly won't like the salt air.
PowerMax PMBC apparently also custom setpoints
Iota DLS-X w/ IQ4 option
Progressive Dynamics
john61ct is online now
The Following User Says Thank You to john61ct For This Useful Post:
post #8 of 31 Old 05-17-2019
p.s. I have East Penn Gel batteries for my house, which I knew to be quality. Made a leap of faith, given my positive experience with WM AGM in a different application.
Jeanneau 54DS
post #9 of 31 Old 05-17-2019
Many boats could have 3 batteries on board. My 30 foot Nonsuch had two house bank batteries and one for the motor.
You might consider a Dual Pro Charger for a shore power charger. They are available for charging one, two, three or four batteries. Order one with an AGM charge profile and you are done.
Mike
Currently: Heading to warm waters over the winter on a variety of boats.
mbianka is online now
post #10 of 31 Old 05-18-2019
SanderO's Avatar
I must have gotten lucky with my AGMs - 8D... Replaced / installed in Early Spring 2012 w/ complete rewire of cables. shunts etc. They seem to be doing fine. Apparently made in Vietnam.
Next install w/ likely be smaller format... These are way to difficult to handle.
pay attention... someone's life depends on it
SanderO is online now
Bilge paint: any brands to favor or avoid? BillMoran Gear & Maintenance 22 05-28-2018 10:06 PM
Any advantage/disadvantage to registering a boat in a particular state? Sleddriver General Discussion (sailing related) 18 11-16-2015 08:44 PM
AGM Battery brands - any feedback? pshearing Electrical Systems 8 08-12-2009 06:52 PM
Mixing different AGM sizes and brands voice3 Gear & Maintenance 4 06-01-2009 01:05 PM
