Quick! New built in fridge advice, seeing the guy in 2.5 hours - SailNet Community
 2Likes
  • 1 Post By colemj
  • 1 Post By chef2sail
post #1 of 4 Old 1 Week Ago Thread Starter
Moderator
MarkofSeaLife's Avatar
Dock
Standard Beneteau production boat 393, 18 years old. I don't use the built in front opening fridge as I use a Dometic portable freezer. But I have some Flash Cash and want to get the big fridge back online.
Its leaking and it looks more convenient to replace the compressor, pipes and the plate.
Current position is extremely difficult (imposable) to access so we will put the compressor in a deck locker (lazarette) with an adjoining wall to the back of the fridge. we will run the pipes through that wall. The mechanic has done a similar installation on a Beneteau 411.
The current fridge is about 110 litres.
Its just a fridge, I will use the Dometic as the freezer.
As its a whole new setup and I can buy what I like (thats available in France)
Questions:
Having installed a whole system before is there advice, trick, ideas that you've learned?
Any pitfalls to beware?
The new location for the compressor will be a much larger area. Should I buy a bigger compressor? (I cant see what size the current compressor is)
Thanks
Mark
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #2 of 4 Old 1 Week Ago
colemj's Avatar
Re: Quick! New built in fridge advice, seeing the guy in 2.5 hours
Originally Posted by MarkofSeaLife View Post
Questions:
You are doing the right thing by replacing it all at once, even though you may only need to replace a bit of it at lower cost.
Make sure the compressor has a good supply of cool air, and that it has someplace to exhaust warm air and not just recirculate it. If you can install it in a way that it ducts in air and exhausts it someplace else, that's perfect. Even if it means making a cheap plenum to separate or duct "cool" from "hot" sides of the same compartment.
Be careful with the evaporator plate tubing because it is thin aluminum and can kink quickly from an inadvertent movement or hit. To make matters worse, the manufacturer ships it all coiled up and it needs to be straightened out to install, then bended again around corners, etc.
Also be careful tightening the fittings between the evaporator and compressor. Use two properly sized wrenches and not spanners or closest metric/imperial. These are easy to spin off or twist their tubes if a wrench slips while tightening. Don't apply ape pressure - the instructions will tell you how many turns of flats are needed after snugging or puncturing the seal.
No, it doesn't work like that. Compressors are matched to the expected heat load at specific speeds. Bigger will be inefficient and use more power, as will smaller. The manufacturer will advise on compressor size given your box size, insulation, and expected environment.
Thanks
Mark
Mark
MarkofSeaLife likes this.
Dolphin 460 Catamaran "Reach"
Manta 40 Catamaran "Reach" - For Sale!
colemj is offline
post #3 of 4 Old 1 Week Ago Thread Starter
Moderator
Dock
Yes the compressor will now be out of the cupboard into the lazarette that's about 8 feet long, 5 feet high, 4 feet wide. It has a lot of junk in it but always has free space of the top 3 feet x 8 feet.
Current location is behind the gally cutlery draw!
I discovered a the compressors are basically the aame: Danfloss BD35F that does fridges 60 litres to 130 litres.
Mine is 110 litres.
Positioning look like it will have much, much better air circulation. And fridge noise will be outside
Ordered today, installed by pros next week.
Mark
Sea Life
post #4 of 4 Old 1 Week Ago
chef2sail's Avatar
Insulation is the key also. If you can with everything out insulate the box more. It will be more efficient and the compressor will run substantially less. Doing tha 10 years ago our diet of amps for refrigeration dropped from 44 ah per day to 20.
We also have a water cooled options for our alder barbar super cold machine and use it in the summer. Give the compressor plenty of room.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
