Voltage drop at the water pump when its ON. - Page 2 - SailNet Community
 21Likes
post #11 of 22 Old 08-09-2019
Skipper Jer's Avatar
Re: Voltage drop at the water pump when its ON.
Can you move the bloody pump closer to the battery?
MarkofSeaLife likes this.
Nor'sea 27
Don't re-accommodate me, Bro
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is online now
post #12 of 22 Old 08-09-2019 Thread Starter
Moderator
MarkofSeaLife's Avatar
Dock
Solved!!!!!!!!!!!!!!!!!!!!!!!
And the Prize for the Winning Advice goes to Degas!
Originally Posted by Degas View Post
3. If there's still a voltage drop then repair/replace your pump. R1 and/or R2 are in your pump.
It was/is the bloody pump!
On the same circuit I have the exact same pump, Jabsco Par Max 2.9 that pumps the salt water into the sink.
Not only the same circuit but the wire splits from close to the other pump.
When the Salt Water pump is on the voltage drops from 13.9 to 13.6 so no real drop at all.
So I think the Fresh Water pump is the problem. I will keep it till it dies as I can change it quickly with the one doing the salt water.
Thanks for everyones help. No re-wiring! Yay!
Frank!
capecodda likes this.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #13 of 22 Old 08-09-2019
Congrats. Just goes to show how knowing how things work may make solutions easier. Now if I could just solve straddling my suspender strap in the WC.
Capt Len is online now
post #14 of 22 Old 08-09-2019
Have you checked/cleaned the wiring from where it splits off from the other pump to the suspect pump? You may not need a new pump.
RegisteredUser likes this.
Jeanneau 54DS
Minnewaska is offline
post #15 of 22 Old 08-10-2019 Thread Starter
Moderator
Dock
Yes, I bypassed that the first day. I will run the pump till it dies. It may never die. I will check to see if it overheats.
Mark
Sea Life
post #16 of 22 Old 08-10-2019
krisscross's Avatar
I would replace the pump now, because it could eventually fry your wires. And then you will be forced to rewire. These pumps are not too expensive and you need to to it eventually anyway.
Plato
krisscross is offline
post #17 of 22 Old 08-10-2019
Definitely replace the pump now. With that large of a voltage drop it is pulling way more amps than it should. When it dies it will probably melt that little wire powering it and you will have a much worse time running a new wire.
SeanM26 is offline
post #18 of 22 Old 08-10-2019
So time as has it's way with the conductors within the pump body ,,,now hanging on by a strand , what's the solution.?
post #19 of 22 Old 08-10-2019
SeanM26 is offline
post #20 of 22 Old 08-10-2019
Ist make sure its the pump.
If it is and you think it has failed prematurely, you have a great opportunity to ***** on net forums.
Good brand pumps usually are good for years, if well fed.
Id replace it when in a happly place....not dark and stormies....
You know its headed towards lock up. Maybe good to warm finger food before final lockdown.
Sounds like you are making things right.
Do this one too.
If you have good experiences with any russian wowen, please report back. Sadly, i never have
Best luck
RegisteredUser is online now
