How much is a battery cycle ? - SailNet Community
post #1 of 4 Old 08-15-2019 Thread Starter
Markwesti's Avatar
My Trojan manual states and I quote , a deep cycle flooded lead acid Trojan batt . needs to be cycled 50-100 times in order to reach full capacity of SOC . One thing the manual does not say is what is a cycle . I was discussing this with a friend and he said "if your batt. is at 100% SOC and you start your engine that would be a cycle , if you charge back up to 100% SOC" . Well that sounded good to me , what do you think ?
Westsail 28 , Patricia A
Markwesti is offline
post #2 of 4 Old 08-15-2019
Re: How much is a battery cycle ?
I think a cycle would be draining the battery 40-50% then recharging. I don't think an engine start will put a big drain on a battery's capacity.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
The Following User Says Thank You to jephotog For This Useful Post:
Markwesti (08-16-2019)
post #3 of 4 Old 08-16-2019
Certainly lower than 20-30% DoD.
None of this is exact.
The break-in period is done when capacity gains appear to plateau.
Ideally keep C-rates gentle both charging and discharging during that time.
You then do a precise CC load test capacity benchmark for 100% SoH, and it's all downhill from there, hopefully taking many years to EoL at ~75%
john61ct is online now
The Following User Says Thank You to john61ct For This Useful Post:
post #4 of 4 Old 08-16-2019
Cranking an engine does not draw even a decent fraction of 1%.
Best to use a SoC meter to let you know.
