Odd Battery setup - SailNet Community
 9Likes
post #1 of 21 Old 09-29-2019 Thread Starter
davidpm's Avatar
Odd Battery setup
Hunter 34 with an odd battery setup.
As you can see someone messed up the battery wiring, didn't even use the right colors.
Any guesses as to what the PO was thinking.
As you can see from my crude drawing a negative wire from the battery is going through the bulkhead and one battery's negative terminal is not even attached to anything.
Any guess as to what the idea was.
I'm guessing that the two red positives go the switch. the negative goes back to a negative bus bar or alternator. On the other side of the switch where I can't see is a red wire to the positive switch panel I suspect.
I'm assuming that it was originally a two battery setup and someone added the third battery and never finished the install.
davidpm is offline
post #2 of 21 Old 09-30-2019
JimsCAL's Avatar
Re: Odd Battery setup
I'm guessing it's a 2 bank setup with 2 batteries connected in parallel for a house bank. I see all the negatives connected. Looks like the two on the right are in parallel.
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
post #3 of 21 Old 09-30-2019
CVAT's Avatar
If the drawing is correct than none of these batteries are connected in parallel or series for that matter, the two that share the negative bus provide two independent 12vdc buses, assuming these are 12vdc batteries. The third with only the positive connected to other other battery is floating, not a good situation as it is neither totally connected nor totally isolated, IMHO.
davidpm likes this.
Use your head for something other than a hat rest.
CVAT is online now
post #4 of 21 Old 09-30-2019 Thread Starter
davidpm's Avatar
I'm thinking that for now, I should just disconnect the positive on the third until we figure out how to do this right.
davidpm is offline
post #5 of 21 Old 09-30-2019
SanderO's Avatar
Why not re wire it properly?
pay attention... someone's life depends on it
SanderO is online now
post #6 of 21 Old 09-30-2019
BarryL's Avatar
Hey,
My guess: A two bank setup. Bank 1 is a single 12VDC battery. Bank 2 is 2 6VDC batteries in series to total 12V.
Barry
chef2sail likes this.
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is online now
post #7 of 21 Old 09-30-2019
CVAT's Avatar
Disconnecting the third and it would be connected correctly if the goal was 2 separate 12 vdc buses, with a common ground bus.
CVAT is online now
post #8 of 21 Old 09-30-2019
all three look like 12v batteries according to the labels. on your schematic, where do the red cables go? if they are connected, then that bank is parallel.
eowin is offline
post #9 of 21 Old 09-30-2019
CVAT's Avatar
Could be parallel yes, if they do go to the same point but that is not what the diagram shows. If they are connected later on this would not be in the best practices for connecting batteries in parallel as it is best to keep the cables connecting the two batteries as short as possible, the added inherent resistance of the cables and connections, as well as the parasitic inductance and capacitance of them also can lead to the batteries to become unbalanced and affect the life of the batteries is connected as such.
CVAT is online now
post #10 of 21 Old 09-30-2019
JimsCAL's Avatar
Just to be clear, I don't think your wiring sketch is correct. If I look at the second pic that shows all three batteries, I see connections on all three negatives.
S/V First Tracks
1985 Cal 33-2
