Autopilot only corrects in one direction - SailNet Community
 2Likes
post #1 of 14 Old 12-23-2019 Thread Starter
We have an Autohelm 4000 (non Raymarine, the black box). It worked fine last summer but now the boat will only correct to port. There is a brown and blue wire that power the motor. When I turn the control unit to the right, I get current across the two wires. When I turn it to the left, I get nothing. I get nothing in either direction if I attempt to press the +/- buttons. When I reverse the polarity switch on the back of the unit, it will correct to starboard but not to port.
Seems like a problem with the control unit, right? Any idea what could be bad or how to troubleshoot further? The compass device is on a gimbal but it appears to move freely in all directions.
glossa is offline
post #2 of 14 Old 12-24-2019
SanderO's Avatar
Re: Autopilot only corrects in one direction
Look for magnetic things near the AP's compass.
pay attention... someone's life depends on it
SanderO is online now
post #3 of 14 Old 12-24-2019
Moderator
MarkofSeaLife's Avatar
Dock
They are significantly old and out of date, arn't they? It might be end of life. But I get the feeling the control head can be replaced without needing to replace the drive... the drive being the expensive bit.
Mark
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #4 of 14 Old 12-24-2019 Thread Starter
I will check. I don't quite understand how the compass works; from what I can see, it doesn't have any moving parts except for the gimbal.
glossa is offline
post #5 of 14 Old 12-24-2019
SanderO's Avatar
any compass will show the wrong reading when a magnet is brought close. Things like magnetic flashlights can foul your compass.
post #6 of 14 Old 12-24-2019
colemj's Avatar
It won't be the compass. Most likely a failure in the power output circuitry in the controller. Probably the FET bank controlling that side of the reversible power output. Unless you can find someone who can do board-level repair, it will be cost effective to get a new controller.
Mark
eherlihy likes this.
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #7 of 14 Old 12-24-2019
dadio917
dadio917's Avatar
happened to us with our alpha 3000....cause was a metal container too close to the compass in a locker. Turns out you don't want any metal close, magnetized or not. Once we moved it everything worked fine.
SanderO likes this.
Dadio917
Valiant 39
dadio917 is offline
post #8 of 14 Old 12-24-2019
CF Escapee
Likely bad solder connection(s) to one or more of the FET transistors (big black flat looking things).
If you or someone you know can solder, it's a relatively easy fix.
senormechanico is online now
post #9 of 14 Old 12-25-2019 Thread Starter
Can the FETs be tested in place?
I also had to disconnect and reconnect the wires to the 4-pin connector to the control head, to replace the mounting block. The unit worked fine before I did this so I wonder if I fried some of the transistors, possibly re-connecting two of the wires wrong. Though the wires do seem to be in the right positions.
glossa is offline
post #10 of 14 Old 12-25-2019
colemj's Avatar
Pull the connector and check to make sure none of the pins broke or bent.
Mark
- Current boat
- Previous boat
colemj is offline
