Battery Series Voltage Difference - SailNet Community
 4Likes
post #1 of 32 Old 12-31-2019 Thread Starter
bell ringer
Don L's Avatar
Looking for theories/reasons why batteries 3&4 have such different voltages in this drawing. The difference stays consistent at different voltages and stayed about 0.3v different during a 3-hr equalization charge.
Thinking that somehow it was the jumper cable between the 2, I took it off and cleaned and tested its ohms. With the jumper off the voltage of 3&4 became the same, but they went back to having the difference after reinstalling.
Don't blow air up my rear, be useful and blow it at the sails!
Don L is online now
post #2 of 32 Old 12-31-2019 Thread Starter
bell ringer
Don L's Avatar
Re: Battery Series Voltage Difference
Well i measured those yesterday near close to fully charged and under solar charging. This morning at 82% state of charge and a charge of 1.2A voltages were closer
1 - 6.21
2- 6.27
3 - 6.25
4- 6.22
Don L is online now
post #3 of 32 Old 12-31-2019
chef2sail's Avatar
What’s the acceptable error on the monitoring meter?
Any parasitic loads? Or charger ie echo charger to one battery?
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #4 of 32 Old 12-31-2019 Thread Starter
bell ringer
Don L's Avatar
other than the things on the paper that say "BM" everything was measured directly at the battery, sure there could be (and probably is) some error but it would apply to all the measured voltage readings
Don L is online now
post #5 of 32 Old 12-31-2019
Is it possible that not all batteries are equal.? ie. some lead has a bit of cadmium (recycled wheel weights?)
Capt Len is online now
post #6 of 32 Old 12-31-2019 Thread Starter
bell ringer
Don L's Avatar
who knows, they are all the same age and batch
but, why would it change between an 8 amp charge, 1 amp charge, at rest?
Don L is online now
post #7 of 32 Old 12-31-2019 Thread Starter
bell ringer
Don L's Avatar
think when I'm feeling physical I'll move the batteries around and change the pairings and locations and see if it follows the battery or the location
Don L is online now
post #8 of 32 Old 12-31-2019
This is why equalisation charging should be done on each string separately, really each unit if you're getting into this level of detail.
I assume not a brand new set?
Fact is no two cells in even the biggest set will ever be exactly the same.
The uneven flow through paralleled strings will cause uneven wear over time, thus a shorter lifespan overall compared to just one string of single cells.
paralleling multiple cells at the lowest level before serial'ing is next best
paralleling separate strings worst case.
Balancing the cells with their corresponding members across the strings would help, but violates KISS principles.
Some owners do rotate units to try to "even out" the wear,
people I tend to trust more say best to just keep them as is, but haven't seen an explanation as to why.
john61ct is online now
post #9 of 32 Old 12-31-2019 Thread Starter
bell ringer
Don L's Avatar
I dont feel that explains anything.
Don L is online now
post #10 of 32 Old 12-31-2019
They may all look good after charging. But operate much differently under load. I have four batteries in a series to make a 48 volt string. All batteries charged up the same. But, one would lose capacity rapidly after a few minutes under load. A quick test with my battery tester confirmed how bad the battery was.
You said your batteries are old so they are probably aging differently. Hopefully they were the same age when they were installed new. A simple test with a Centech Battery tester would show how each battery compares to the others internally as shown in the link below.
https://biankablog.blogspot.com/2019...tery-bank.html
Mike
Currently: Heading to warm waters over the winter on a variety of boats.
mbianka is online now
