Once again, solar questions..... - SailNet Community
post #1 of 14 Old 2 Days Ago Thread Starter
RichF28's Avatar
Should a solar panel be installed with a cut out switch? Our boat has a simple volt meter on the panel to check battery voltage in each bank. When the battery charger is plugged in it will read the output of the charger, 14.8v. The solar controller is wired direct to the battery also. It seems to me that the voltmeter would be reading the output of the solar controller, not the battery. Is that correct?
Thanks
RichF28 is online now
post #2 of 14 Old 2 Days Ago
Re: Once again, solar questions.....
I dont have inline solar controller disconnects
Just the all on/off to the bar
Youre still reading the batts on your system
I can read the controllers input separste from other inputs..if i want to
RegisteredUser is online now
post #3 of 14 Old 2 Days Ago
Up to you, long as you can disconnect without too much trouble, or throw a blanket over them
The **circuit** voltage while charging is a "compromise" between the lower battery V, the demands of concurrent loads and the higher "striving" of the SC output.
Only when charging is stopped will the battery start to settle to its "at rest" V, unless the circuit gets pulled down lower than that by active loads.
To the extent reading at the bank posts differs from at SC output, you might need to reduce that distance, and/or get fatter wiring.
john61ct is online now
post #4 of 14 Old 2 Days Ago
Master Mariner
capta's Avatar
As I have a fuse on the input from the controller to the batteries, that is my disconnect point. As I would assume you have the same, you shouldn't need anything else.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #5 of 14 Old 2 Days Ago Thread Starter
RichF28's Avatar
Thanks for the replies everybody. Just for convenience, I'm going to mount a switch next to the controller. Its good that someone mentioned fuses between the battery and controller, I had overlooked that.
post #6 of 14 Old 2 Days Ago
Between the bank and the SC is its output.
Do you mean you have fusing at its input, between the panels and the SC? That's where OP is talking about.
post #7 of 14 Old 2 Days Ago
colemj's Avatar
A switch between the panels and controller is convenient. Most controllers shouldn't be cut from the battery while the panels are still providing power, so if you need to work on something, it is convenient to be able to switch off the controller appropriately through shutting down its input before cutting its output.
Other than that, there isn't any wire protection considerations to worry about, because a short won't be a problem on that side of the circuit.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #8 of 14 Old 2 Days Ago
Just a bit nitpicky, but although panel is the input, the power source for running the SC is the bank.
So it does not get "switched off" until disconnected from the batt, or by an internal switch if available, from your phone or whatever.
post #9 of 14 Old 2 Days Ago
colemj's Avatar
Whichever means one needs to disconnect the controller from battery power is the means by which the controller is switched off. This is self-evident, and correct. Removing the input before switching off the controller (by whichever means it needs) is the safest procedure, and a required procedure for some controllers.
I'm trying to help here, John.
Mark
- Current boat
- Previous boat
colemj is offline
post #10 of 14 Old 2 Days Ago
Yes I just pointed out that is when the SC gets turned off, not from the prior cessation of panel input (including a blanket)
And I did say it was a minor point.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
[email protected]
