cooling water back pressure - SailNet Community
 1Likes
  • 1 Post By colemj
post #1 of 3 Old 03-21-2020 Thread Starter
Master Mariner
capta's Avatar
Sorry, not cooling water, but feed water.
We've been using a 12 volt Water Puppy (6.3 gpm) as a boost pump for our watermaker, but they do not like the back pressure from the high pressure pump (2.3 gpm) and over heat and fail after some time.
We have a 110 volt Dometic/March water cooled continuous duty magnetic drive pump (8.3 gpm) that will do the job quite nicely, but I have no idea if the back pressure will damage the magnetic drive pump.
I assume that the magnetic drive will not be affected by back pressure, as the Water Puppy was, because there is no direct drive between the motor and impeller. We have run the magnetic drive pump with the thru hull partially open and that does significantly reduce the water flow, but again, I have no idea if this will damage the pump.
We would appreciate any thoughts on this.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #2 of 3 Old 03-21-2020
colemj's Avatar
Re: cooling water back pressure
I'm assuming you do not have a Spectra or similar energy recovery unit that uses the feed pump as a pressure pump.
If this is correct, then a March pump or similar magnetic drive will work just fine, as long as it is sized to provide sufficient flow to feed the HP pump. Don't go by its open flow rating, but look at where it is rated for ~3-4' head because this is more indicative of how it will be used in this application. We used one for several years on our previous boat.
Another option is to use a bypass valve on a diaphragm pump like the Water Puppy, that diverts extra flow beyond what the HP pump takes back into the feed stream. A bit difficult to explain, but you put the bypass valve in parallel between the input and output of the feed pump. The HP pump takes what it needs, and the remainder is just continually circulated. This way the feed pump does not turn on/off/on/off... and burn out - it just runs. Of course, it needs to be rated for continuous duty for this. We have also used this in a watermaker application for several years.
A third option is to use a variable speed pump like the Jabsco VFlow 5.0, which will run at high duty cycle, and adjust its flow to match that of the HP pump. Our current watermaker uses this pump, but it is new and I can't report on its long-term performance (although it is warranted by the watermaker company for 5yrs in this use).
Mark
capta likes this.
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
The Following User Says Thank You to colemj For This Useful Post:
capta (03-21-2020)
post #3 of 3 Old 03-21-2020 Thread Starter
Master Mariner
capta's Avatar
Thanks.
We are in full quarantine here so we've literally got to work with what we have aboard, so it's just the March pump and some hose. Your first answer pretty much confirms my assumption, so we'll have to go with that.
If and when I can acquire 3/4" hose barbs and hoses we'll replace the 1/2" lines which I hope will further alleviate the pressure to the high pressure pump, but who knows when that will be.
capta is online now
