Making wooden spreaders. Material? - Page 5 - SailNet Community
 23Likes
post #41 of 49 Old 06-25-2015
Once known as Hartley18
Classic30's Avatar
Dock
Re: Making wooden spreaders. Material?
Originally Posted by L124C View Post
I'm going with spruce.
Use CPES instead of West 105/202 (for example)?
What paint should I use?
Bed all hardware including spreader tips? Doesn't the epoxy isolate the wood from water?
Ok.
Yes.
A white topsides enamel of some kind 2-pack or 1-pack as you like over a proper Yacht Primer.
I would.. only because I'd rather not go up there just because something has loosened off.
Yes.
Have fun!
Classic30 is offline
post #42 of 49 Old 06-25-2015
aeventyr60's Avatar
Tradition has the underside varnished...well, for me anyway.
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #43 of 49 Old 06-25-2015
TomMaine's Avatar
You can do that, or take the easy way out. Build a typical varnish coating:thinned first and second coat, then 5 or 6 coats un-thinned, sanding lightly between coats. Do the whole spreader.
When that's dry, tape off the top surface, lightly sand, apply a couple coats of hardware store white enamel(only the seagulls will see it). Then install any hardware, and yes, bedding compound.
For maintenance, lightly sand, varnish the whole spreader, right over the paint.
Eventually, every coating will need removal. Plain varnish comes off easily, as does the paint on top.
Tom Young sailing a 1961 38' Alden Challenger, CHRISTMAS out of
Rockport, Maine.
'I'd have written a shorter post, but I didn't have the time', Mark Twain.
TomMaine is online now
post #44 of 49 Old 06-25-2015
Classic30's Avatar
Dock
Oh, well.. too late for me!
post #45 of 49 Old 06-25-2015
aeventyr60's Avatar
^I'll send you a bit of 80 grit...
post #46 of 49 Old 06-25-2015
Classic30's Avatar
Dock
Thanks... (I think)
post #47 of 49 Old 06-28-2015
aeventyr60's Avatar
How it should look:
post #48 of 49 Old 07-01-2015
Argyle38's Avatar
Dock
I'm not familiar with West 105/202 so I can't comment on that. I do know that CPES is very thin and soaks in to the wood before it cures. This effectively turns a thin layer of wood in to "wood reinforced plastic" and seals off the wood from water ingress. If West 105/202 does that as well then that may be an option.
I use white one part polyurethane on the top side of the spreaders. Brightside is the type, forget the brand, they sell it at west marine. It seems to hold up fairly well. The paint seems to bond well with the CPES epoxy.
I use Cetol light on the sides and underside. Looks good enough for me, I ain't no museum boat after all, especially from 30' away.
Yes, I do think it's a good idea to bed everything with a sealant that is removable (i.e. not 5200). You will want to be able to remove, inspect, and clean things up from time to time. I use 4000UV there. LifeCaulk might work well there too. The CPES ideally will keep water out, but when hardware gets attached, it could compromise the epoxy coating to some extant and water could work it's way in to small gaps between the hardware and the wood. If there's a small crack or gauge in the epoxy, then that becomes an ideal place for rot to start since the water won't evaporate away very fast from down inside a crevice. So the sealant is there to prevent that as much as possible. Belt and suspenders kind of thing.
S/V Argyle
Downeaster 38 #40
Argyle38 is offline
post #49 of 49 Old 07-02-2015
aeventyr60's Avatar
+1 on the Brightsides for the spreader and the mast. I thinned the paint out for the first few coats as the temperature was in the 90's.
repairing wooden spreaders with mast steps installed dan8152 Gear & Maintenance 14 05-22-2015 03:57 PM
Cal 2-27 Spreaders SteveMartin Gear & Maintenance 5 07-11-2009 09:43 PM
spreaders Leland Gear & Maintenance 22 05-20-2008 06:24 PM
Spreaders sailaway21 Gear & Maintenance 7 04-03-2007 07:26 PM
Looking for Spreaders RookieHunter Gear & Maintenance 5 11-23-2002 04:23 PM
