Torque wrench - Page 2 - SailNet Community
 1Likes
post #11 of 16 Old 03-07-2014
jimrafford's Avatar
Re: Torque wrench
If you have to buy a 3/4" and will rarely use it. Harbor Freight tool, $80.
Jim
S/V Deja Vu
CS 40
jimrafford is offline
post #12 of 16 Old 03-07-2014
Senior Citizen
Chas H's Avatar
Re: Torque wrench
Originally Posted by jgeissinger View Post
You can a torque wrench from any number of sources, Sears being a good one. However, be aware that whatever torque values you find for your size keels bolts and nuts is for Clean and Lubricated fasteners. Just tightening them as they are, in a generally semi-corrosive environment, where they have likely been untouched for years, will not give you anything like an accurate reading.
Would it be a good idea to remove all of the nuts or remove them one at a time to clean the threads before torquing to insure an accurate reading?
Chas H is offline
post #13 of 16 Old 03-08-2014
Senior Moment Member
SloopJonB's Avatar
Re: Torque wrench
One at a time - you can do that in the water.
This is an instance where a cheapo torque wrench will be plenty good enough. Many, many keels have been tightened with nothing but a wrench and a long piece of pipe "until the suckers screamed".
Keel bolts aren't a situation like the main bearings on an engine where very precise torque is critical. A cheap wrench will give EVEN torque on the bolts, even if it isn't accurate to the Ft. Lb.
On the other hand, this is also a perfect situation for rented tools.
smurphny likes this.
SloopJonB is online now
post #14 of 16 Old 03-08-2014
Junior member, rest old
msmith10's Avatar
Re: Torque wrench
I did this job several years ago to fix the c&c smile. I bought a torque multiplier on ebay for the purpose. The correct torque is 300 ft lb. that's a lot of torque and you'll either need a torque multiplier or a BIG torque wrench. you'll need a deep well 1-1/2" socket on an extension. You'll either need 3/4" drive socket, extension and torque wrench, or, as I did torque multiplier on 1/2" torque wrench with 3/4" components elsewhere. You can do it in the water as suggested above, but if you can do it on the hard you can do a really complete job-
Loosen the nuts with the keel well-blocked, clean out the hull- keel joint and recaulk, then working one nut at a time, remove a nut and washer, clean out undre the washer, checking visible portion of bolts for integrity, and fill/caulk under, then replace washer and nut, loosely torque. After all nuts have been done, torque all together in steps like you would a cylinder head.
Not as good as dropping the keel, but a lot less work, and as my boat was fresh water it's whole life, everything was still sound.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #15 of 16 Old 04-07-2014
Senior Citizen
Chas H's Avatar
Re: Torque wrench
Best to torque on the hard if possible with the keel supported. You want to measure only torque/twist/resistance on the keel bolts without the weight of the keel pulling against the nuts and washers. I suppose if you torque, re-torque and re-torque while lifting a loose keel in the water the readings may get more accurate as a keel is lifted into position. This may be too picky of a method as the keel should not be flopping like a flag under the boat. My boatyard says do it on the hard.
-CH
Chas H is offline
post #16 of 16 Old 04-07-2014
Over Hill Sailing Club
smurphny's Avatar
Re: Torque wrench
Yep. A cheapie will do just fine, actually better than the expensive clicker which will be more easily affected by corrosion. It is actually a tool you should have aboard if you ever have to do engine work. As in torquing any set of bolts, take 'em up little by little, alternating as you go. Agree that being corroded will not allow a good torque reading so get some PBS Blaster and free them up if possible before tightening.
smurphny is offline
drivesaver torque???? redhead78 General Discussion (sailing related) 1 06-11-2010 10:22 PM
To torque or not to torque davidpm Gear & Maintenance 22 11-15-2009 11:37 AM
How about a golden wrench?! SurfingSS General Discussion (sailing related) 7 01-28-2009 09:46 AM
NavPod wrench of key? Where do I get a replacement? countrybumpkin Gear & Maintenance 13 09-08-2008 10:09 PM
name of that wrench... bradfalk Gear & Maintenance 11 08-04-2008 12:03 PM
