Control lines for Lewmar traveller size 2 - SailNet Community
post #1 of 11 Old 04-20-2014 Thread Starter
Looking for some ideas for what size and type of line for a lewmar size 2 traveler.
Specs:
Mid-boom sheeting
Boat Length 40'
My current cordage is not working. It swells up and is binding/slowing my car down. Just the the wrong stuff for the job. Wrong size and all.
I can't find the specs for this traveller on-line.
Looking for something that is slippery, less kink.
Would New england ropes regatta braid 8mm work? or go with 10mm? Single braid?
I know what they recommend; what do y'all think?
Any recommendations would be much appreciated.
benesailor is offline
post #2 of 11 Old 04-20-2014
Re: Control lines for Lewmar traveller size 2
The current size 2 is supposed to handle up to 10mm, but I would recommend nothing larger than 9. The smaller the line the easier it moves inside the blocks and as mentioned over time line swells.
Beyond size, you don't need strength, just something that doesn't absorb water.
Greg
Stumble is offline
post #3 of 11 Old 04-20-2014 Thread Starter
thanks
post #4 of 11 Old 04-23-2014
I don't discuss my member
zz4gta's Avatar
I use salsa line on my traveler and others that I rig. It works really well and runs very fast.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #5 of 11 Old 04-23-2014 Thread Starter
Saw that yesterday
It was recommended at the sailshop that i avoid single braid dyneema because it is slippery and may slide thru the cam cleats.
I believe i'll get samson MLX; polyester covered dyneema core.
Product
Is the Salsa slippery?
Thanks
post #6 of 11 Old 04-23-2014
A couple of things...
1) the biggest issue with traveler lines is that they twist inside the blocks. Any single braid is far less suseptable to this than any double braid. Since the core and cover can start to twist inside each other leading to hockles. Salsa is one of many single braids that works fine to control this.
2) the second biggest issue is that the cover can get hung up and pushed down the core. Causing fattening of the line (another reason to not use double braid.
There are a lot of good single braid lines on the market that will work. Since a traveler typically only has very moderate tension there is no need for high tech stuff like dyneema or salsa. Things like Tenex work fine at much lower prices. That being said I have amsteel traveler lines since it was in my bag when I went to replace the traveler last time and I was too lazy to replace it after it was on.
Dyneema is slippery stuff, but it works fine in cam cleats. At least in low load applications like travelers. I wouldn't trust a jib sheet to a cam alone.
Greg
Stumble is offline
post #7 of 11 Old 04-24-2014
Originally Posted by benesailor View Post
Saw that yesterday
Product
Thanks
I love MLX, I've gone to it for jib and staysail sheets and furling lines, but I think it would be a poor choice for traveler controls, for the reasons that Stumble describes...
I agree that a line like Salsa would be best, no problem holding in a cam cleat, and it has a nice hand which can be important with traveler control lines. If you don't care for the color/appearance of Salsa, Regatta braid would be a decent choice. Regatta Lite could also be nice, but containing some polypro won't last as long due to UV degradation... The relatively new PhD rope from Yale could work nicely, as well - I'm using that for my mainsheet now, it's non-hockling and runs through blocks very nicely...
Samson made a line called Apex, very similar to Salsa, which would make a great line for this application, but it's been discontinued. Some vendors might still have some laying around, however, it was only available in yellow/white...
JonEisberg is offline
post #8 of 11 Old 04-24-2014 Thread Starter
Thanks all for the clarification; i guess i'll rethink this. Look at some salsa
post #9 of 11 Old 04-24-2014
zz4gta's Avatar
I've never had salsa slip in a cam cleat. I like MLX, and it's a blended core, I'm using it form my mainsheet, but the salsa works very well as a traveler line.
Tenex, if it works for Stumble, than that's fine, I would never spec it out though. Regatta lite stretches, a lot, and doesn't last that long. Its fine for runner tails, but not much else.
zz4gta is offline
post #10 of 11 Old 04-24-2014
Zz,
You are talking about a 8mm line with a working load of what 25-50lbs? Sort of using bungee cord stretch isn't going to be a concern.
Again I don't like any double braids for traveler lines since the cover and core always wind up twisting inside each other. But almost any single braid will work. I personally prefer lines that don't absorb water for travelers since they are always in the cockpit and get wet and stepped on. But the water thing is personal preference not required.
Any dyneema cored double braid is ridiculously over specced. Remember traveler lines have very low loads so they don't need the strength.
Greg
Stumble is offline
Size & Type: Dock lines vs. Mooring lines JordanH Gear & Maintenance 23 05-19-2011 10:29 PM
Moving control lines to the cockpit? Garffin Seamanship & Navigation 9 11-29-2009 04:58 PM
Control lines set-up for singlehanding OhioTom Seamanship & Navigation 9 08-28-2009 10:48 PM
Lewmar Traveller Shortman Gear & Maintenance 12 03-22-2009 07:35 AM
Leading Control Lines Aft chtaylor Gear & Maintenance 57 08-23-2008 12:25 AM
