whether or not to glass a wooden rudder - SailNet Community
post #1 of 3 Old 04-22-2014 Thread Starter
I have a transom-hung wooden rudder. It is basically a 6 foot long slab of teak or mahogany that has weathered varnish above the waterline and chipping bottom paint below. I scraped away some of the bottom paint and found what looks like old varnish underneath.
Even though the boat will mostly live on the trailer and be in the water for only a week or two at a time, I am considering wrapping the rudder below the waterline in glass and epoxy and fairing it. Or is that a bad idea, letting any water that might get into the bottom part of the rudder just stay there a cause rot? Am I better off just varnishing the whole thing? Is it better to glass it all? If I fair with teak flour and epoxy, then glass with clear epoxy and project with a few coats of varnish, it would still look wooden and I might see any trouble before it gets too bad. Is that a good plan or am I missing something?
meteuz is offline
post #2 of 3 Old 04-22-2014
christian.hess's Avatar
Re: whether or not to glass a wooden rudder
the only issue with wooden rudders out on the dry is they warp out if shape when out of water for too long
if you dismount it you are asking for trouble as its common for the pintles to not align well...
since you are out of the water I see no benefit at all in glassing the rudder when the rest of the boat is still wood
you can fix wooden rudders quite easily and fair and epoxy them instead of glass...
just a thought
I had a nice long rudder like that on my old h28
simple to live with did nothing to it even after being on the hard for close to a month once
the rudder did warp and after a week or so back in water it went straight again...and so did the planks stop leaking
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #3 of 3 Old 04-22-2014
Once known as Hartley18
Classic30's Avatar
Dock
I'd suggest:
1. Use a heat gun and scraper to remove the old paint/varnish
2. Sand back using a random orbital and 80 grit going to 120 grit if the surface is fair. If not, fair at will using your teak flour/epoxy mix.
3. At least one coat of two-pack CPES - note: this will cause any one-pack varnish you missed to bubble and flake off, in which case go back to 2 and repeat.
4. A light sand using 120grit followed by several coats of varnish (or paint) as you prefer.
As Christian points out: Don't glass it - bad idea.
Classic30 is offline
My wooden rudder needs to be painted or something steel Gear & Maintenance 13 08-12-2013 08:59 PM
rework or leave alone the old wooden rudder ABH3 Boyer Gear & Maintenance 6 11-28-2012 02:17 PM
paint for wooden rudder Mick Young Gear & Maintenance 1 05-19-2007 09:06 PM
Glass hulled Wooden Boats JakeLevi Boat Review and Purchase Forum 5 11-01-2006 07:13 PM
rudder, glass or wood? jbarros Gear & Maintenance 8 05-08-2003 10:32 AM
