ST60 wind display - SailNet Community
post #1 of 6 Old 04-22-2014 Thread Starter
ST60 wind display
Does anyone know if the newer ST60+ (ie plus) is reverse compatible? I doubt it. I have a non-plus version that needs to be replaced.
Better yet, does anyone know a source for a used/refirb ST60 display?
Jeanneau 54DS
Minnewaska is offline
post #2 of 6 Old 04-22-2014
Super Moderator
Maine Sail's Avatar
Re: ST60 wind display
The plus display will work fine...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #3 of 6 Old 04-23-2014 Thread Starter
No kidding, MS? That's not the Raymarine I've gotten to know so well.
Well, that's good anyway, but I now realize the plus display is not going to look right along side the non-plus tridata and autopilot. Maybe that's a little finicky.
Does anyone know of a source for these used instruments? I've done a little searching without success, including ebay.
btw, the only problem with mine is the interior needle on the wind instrument is dragging on the inside glass and gets hung up. There is some chance I could do surgery and repair, but the odds are 50/50 it's irreparable.
Jeanneau 54DS
post #4 of 6 Old 04-23-2014
Delta-T's Avatar
I got what you need. My anemometer bearing went two years ago and I opted to buy the entire instrument kit, was the cheapest route. And I was missing one cover, and the new instruments are shaped a little different, not enough to really notice, but the new cover will not fit the old, so I changed the gauge too. The old one is in pristine condition...no cover.
Edit: It is the ST60+
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
post #5 of 6 Old 04-24-2014 Thread Starter
Originally Posted by Delta-T View Post
I got what you need. ......
Thanks!! PM sent.
Jeanneau 54DS
post #6 of 6 Old 04-27-2014
redline's Avatar
You can swap the housing. I replaced an ST60 Winfd with an ST60+ wind and installed the new + in the old 69 housing. Looks like the other five, only the + on the dial shows the difference. And holding the left button can shut it down.others
Sent from my iPad using Tapatalk
Norman
s/y "Redline"
1998 Jeanneau SO45.2
redline is offline
NKE wind transducer to which wind display via NMEA 0183? Rupeski Electronics 9 02-12-2014 01:29 AM
ST60 Windspeed Display Jemill Electronics 4 10-09-2012 03:02 AM
Raymarine ST60 Wind tdw Electronics 9 12-28-2011 08:44 PM
How to get the SOG on a ST60 speed display? r1texas General Discussion (sailing related) 4 12-05-2009 12:57 PM
ST60 wind initialize? mikehoyt Gear & Maintenance 5 10-02-2008 09:04 PM
