New turnbuckle lube recommendatns - SailNet Community
post #1 of 7 Old 04-24-2014 Thread Starter
Dave_E's Avatar
Hi All,
I have brand new shiny turnbuckles and new standing rigging. Does anyone have a recommendation for a good lubricant/protectant?
Dave
Allmand Sail 31 #15 "Traveler"
GOD, Family, career
Dave_E is offline
post #2 of 7 Old 04-24-2014
Once known as Hartley18
Classic30's Avatar
Dock
Re: New turnbuckle lube recommendatns
Lanocote. Can't really do better than that.
..with maybe some machine oil on the threads to help first-time assembly.
Classic30 is offline
post #3 of 7 Old 04-24-2014
I use Brake lube, seems to work fine. Then again, i unstep my mast every year for storage. I've heard that lanacote is the champ.
http://www.autozone.com/autozone/acc...er=752442_0_0_
Silicone base brake lubricant recommended for the entire brake assembly and is compatible with rubber. It is moisture-proof and heat resistant to over 600 degrees F, which means it won t burn-off like other brake noise products.
Reduces noise in brake assemblies
Will not run off in high temperatures
Can be used on all brake parts
High film strength
benesailor is offline
post #4 of 7 Old 04-24-2014
Tef-gel, cleaned up with denatured alcohol.
IStream is offline
post #5 of 7 Old 04-24-2014
I don't discuss my member
zz4gta's Avatar
Lanacote or tef-gel are the two major players. Tef-gel is a little sticky but not horrible. I've seen stuff brake loose with a screwdrive that has been in the mast for the better part of a decade with tef-gel. I don't have any personal experience with lanacote, but have heard similar result. Amazing stuff.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #6 of 7 Old 04-24-2014
Noah's Bosun
Cap-Couillon's Avatar
Another vote for Lanocote.... Also use it for stainless/aluminum barrier coat, doping electrical plugs on the mast harness, holding a loose gasket in place while seating a part, lube and corrosion prevention on my Opinel pocket knife, anchor shackles, and a million and one other things...
The sailors friend. A little bit of sheep grease goes a long ways.
Cap-Couillon is offline
post #7 of 7 Old 04-24-2014
christian.hess's Avatar
well any grease/lube is better than nothing
not being close to places that carry tef gel and the like I used some nice texaco grease...on some of my new stuff as well as the old while tuning the rig...
one of my old turnbuckles was seized, but thankfully a machine shop did a nice job of freeing it up...
anywhoo
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
Head lube LinekinBayCD Gear & Maintenance 1 09-01-2012 09:24 PM
Get the lube out. (Again) mdbee Politics, Current Affairs, Guns & HOT Topics 1 10-21-2011 12:37 AM
C33 Cable Lube meuritt Gear & Maintenance 2 08-11-2011 08:03 AM
My lube oil has fuel in it myaticj51 Diesel 8 07-03-2009 10:23 AM
head lube rchad Gear & Maintenance 4 08-01-2007 03:57 PM
