Are These Winches Salvageable? - Page 2 - SailNet Community
 18Likes
post #11 of 39 Old 06-02-2014 Thread Starter
ericb760's Avatar
Re: Are These Winches Salvageable?
Originally Posted by fryewe View Post
eric-
If you visit the blog sundownersailsagain.com (restoration of a Westsail 32) Tate just posted a detailed discussion including a video of maintenance on a set of Lewmar 43s...and included a link to mainesail's excellent tutorial on servicing winches. Both are detailed visual guides to servicing winches including cleaning.
Good luck. (Mineral oil...odorless and effective.)
Thank you, I'll check it out.
ericb760 is offline
post #12 of 39 Old 06-02-2014
Tartan 27' owner
CalebD's Avatar
Gasoline: a highly effective de-greaser and it is flammable!
Everybody has one:
CalebD is offline
post #13 of 39 Old 06-02-2014
Ours looked similar to that: it took two of us about 8 hours for each winch, using mineral spirits, toothbrushes and rags.
Greenhand is offline
post #14 of 39 Old 06-02-2014
Wonderinlost's Avatar
Brake clean is nice but sure is horrid on the hands and any gloves you try to wear. Then it splashes into your face and it burns on a nice hot day.
I am all for gas, diesel, or kerosene with a tooth brush. Let soak a day to rehydrate and losen up the grease. Its just bearing grease.
Wonderinlost is online now
post #15 of 39 Old 06-02-2014 Thread Starter
ericb760's Avatar
UPDATE: This was the first level of cleaning with brake cleaner and a roll of paper towels:
This was as clean as I could get the bearings with the cleaner and a toothbrush. All the bearings are spinning freely but they are still quite dirty. Can I use a wire brush to clean the rest of the gunk off?
And finally, two of the four pawls seem to have been worn away on one side. The two on the right were from one side of the winch. I'm assuming that this is not normal and that they will need to be replaced. Can someone confirm this?
ericb760 is offline
post #16 of 39 Old 06-03-2014
Senior Moment Member
SloopJonB's Avatar
Replace the pawls - springs too probably. Use a brass brush on the roller bearings - they must be bright & shiny - keep working until they are.
Try soaking them overnight or longer in brake cleaner.
Polish up the races inside the drums with some 1000 grit and WD40 or kerosene.
ericb760 and christian.hess like this.
SloopJonB is offline
post #17 of 39 Old 06-03-2014
christian.hess's Avatar
I cant remeber how mine looked...but Im almost sure they were flat all around...
I just rebent the springs out a bit and that will give them more resistance...I usually do that on all mechanical engine springs and the like...
or just buy new ones since you are getting new pawls...
I would soak those races and then mechanically clean them up and or polish
looking good btw...
those winches will be back in business in no time...
ericb760 likes this.
Merit 25 sold...Islander 36 still afloat? who knows...Im still in Columbus, and back...I think...jajajaja!!!!
christian.hess is offline
post #18 of 39 Old 06-03-2014
I've used kerosene, diesel, WD40, mineral spirits, alcohol, lacquer thinner, whatever is at hand. Mineral spirits would be my first choice though. I'll have to try some citrus solvent and see if that works as good, it's be nice to move away from petroleum solvents.
I've also wondered if Carb dip that comes in the 1 or 5 gallon cans wouldn't be an easy and effective way to clean them. I've used the carb dip to clean up some seriously gunked up carbs, leave it in over night pull out and rinse off and they look like new. It might be easier than going at them with tooth brushes. Just a thought.
I don't think you can blame or even guess as to what the last guy used. If it hasn't been done in 30 years any grease is going to get gunky after that long. Besides waterproof wheel bearing grease is probably a great option if not the same stuff you buy in the little tubes at 4 times the price at West Marine.
appick is offline
post #19 of 39 Old 06-03-2014 Thread Starter
ericb760's Avatar
Can someone confirm that this is what I need in order to replace the pawls and springs?
Lewmar Standard Small Pawls & Springs Kit: Mauri Pro Sailing
ericb760 is offline
post #20 of 39 Old 06-03-2014
I've also seen boiling parts in lemon juice either straight or cut with some water as a great way to clean. Haven't tried that yet either but worth thinking about and of course non toxic.
appick is offline
Isuzu 2AB1??? Full of fresh water - salvageable? Halberdier Diesel 6 11-13-2012 08:45 PM
Advice: Is this dinghy salvageable? EricinToronto Gear & Maintenance 14 03-08-2011 07:20 AM
One Bad Cell - Salvageable or Junk? CS271409 Electrical Systems 4 03-22-2010 10:10 PM
