Campbell Sailor Prop vs. Max-Prop? - SailNet Community
 6Likes
post #1 of 37 Old 09-30-2014 Thread Starter
I am in need of a new prop as I am moving to a slip (from a mooring) which will require a good reverse. I now have a Gori folding prop that is essentially worthless in reverse in terms of any directional control. I don't race but like that my boat performs well under sail. A new 3 blade Campbell is about 60% of the cost of a reconditioned 2 blade Max-Prop. I know the Max-Prop will be more efficient through the water under sail, but I don't know if there is a substantive difference between the two. Additionally, the Campbell can be fitted without a haulout. When I had a fixed conventional 2 blade prop and switched to the Gori, I picked up 1/2 knot at 6 knots of speed. I'm not crazy about giving that up.
Thank you in advance for your thoughts.
Regards,
luv4sailin is offline
post #2 of 37 Old 09-30-2014
Re: Campbell Sailor Prop vs. Max-Prop?
I don't have any experience with the Campbell, but FWIW my 3 blade Maxprop is great in reverse.
IStream is offline
post #3 of 37 Old 09-30-2014
We've had both.. a Campbell on our last boat (3 blade) and a 3 blade Max on the current boat.
Same engine both instances but the Campbell was on a bigger (40 ft vs 35) boat.
While the Campbell was a big improvement on the 'floppy worn out folder' we had previously, the increase in drag was noticeable but reverse was pretty good/much better than folder.
Campbell to Max in reverse is night and day. The Max is a joy to use in reverse, smooth in forward (as was the Campbell) and clean under sail.
FWIW I think you'll be happy to have spent the extra money at the end of the day. The support/service of PYI is very good too.. but WestbyNorth is a great outfit to deal with as well..
jrd22 and T37Chef like this.
Faster is offline
post #4 of 37 Old 09-30-2014
djodenda's Avatar
I was going to mention this previously, but since you brought it up...
When I changed from my two-bladed fixed prop to a 3-bladed Max Prop, my backing performance didn't seem to change noticeably..
I still have prop walk, but it doesn't seem to be much different, and backing power was and is plenty..
(36 foot 14,000 lb boat)
Go figure
David
1987 CS 36 Merlin "Kyrie"
djodenda is offline
post #5 of 37 Old 09-30-2014
David.. on this boat we went from 2 blade fixed to 3 blade Max too.. I notice less propwalk and more immediate reverse way at idle/in gear than the old fixed prop. If you 'goose it' in reverse I'd agree there's not much difference - in both response and propwalk.
I'm happy, btw, that the Max has not eliminated propwalk as some claim.. I like it and use it often.
Faster is offline
post #6 of 37 Old 09-30-2014
Master Mariner
capta's Avatar
If you go with the Campbell, are you going to need a shaft brake, or are you going to let the prop freewheel?
I think the MaxProp is the way to go today. I tried several of the folding props over the years, and every one came up far short of a reliable propeller system. The mechanical feathering props are far superior in design and function.
I don't see why anyone would consider a fixed prop today, unless they had a motor vessel.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #7 of 37 Old 09-30-2014
no longer reading SailNet
Alex W's Avatar
I had a Campbell Sailor 3-blade and now have a 3-blade feathering prop. I've also had a conventional (Michigan Sailor) 2-blade prop on the same boat.
The reduction in drag while sailing with the feathering prop is huge, especially in light air. For me it is the difference between sailing in 5-8 knots and motoring when cruising. The feathering prop allows me to do a lot more sailing in our light-air summers.
A CS 3-blade has about the same drag as a conventional 2-blade. The blade surface is a little smaller, but it isn't a huge reduction.
My feathering prop is a Featherstream (made by Darglow) and it was installed while the boat was in the water by a friend. I've also installed a Max-Prop, this was significantly less work because the blade is assembled first and then installed. The 3-blade Featherstream was only slightly more than a 2-blade Max-Prop, and considerably cheaper than a 3-blade MaxProp.
Reverse is very good on the Featherstream (just like a Max-Prop). My boat still has a little prop-walk, but it seems to be reduced from the Campbell Sailor. I can't say for sure because I also changed my rudder locks at the same point and have more rudder control now then when I had the CS.
Alex W is offline
post #8 of 37 Old 09-30-2014
4arch's Avatar
Expense. Vibration. I've never been able to get any non-fixed prop to run as smoothly as a fixed.
s/v Spindrift
Beneteau Oceanis 400
formerly Lippincott 30
4arch is online now
post #9 of 37 Old 09-30-2014
I don't discuss my member
Fstbttms's Avatar
FYI- no haulout needed to install a Max Prop. PYI can recommend qualified divers in your area.
Fstbttms is offline
post #10 of 37 Old 09-30-2014
Regards,
Hey Ron,
Here's my take on the Campbell Sailer from a similar thread a few weeks ago...
https://www.sailnet.com/forums/2155105-post12.html
bottom line, it's a nice prop in flat water, and for maneuvering, but don't expect it to work wonders punching thru a significant chop, or into a stiff headwind... Of course, I wouldn't expect that from a 2-blade Max-Prop, either...
As for drag under sail, I can't really quantify that... Certainly hasn't seemed excessive to me, I had a lot of light air sailing this summer, yet still seemed to manage some pretty decent passage times...
JonEisberg is offline
Campbell Sailor Brand Prop Question dacap06 Gear & Maintenance 10 04-30-2013 10:04 AM
PSC37 Campbell Sailer Prop.. any advice whimbrel Pacific Seacraft 6 10-26-2011 11:24 AM
Prop walk with a Max Prop ikent Gear & Maintenance 19 06-05-2011 08:32 PM
Campbell Sailer Prop Problems halyardz Gear & Maintenance 1 09-16-2003 06:20 AM
Campbell Sailor prop sailr303 Gear & Maintenance 0 02-18-2002 04:06 PM
