Water Tank access port - SailNet Community
 2Likes
  • 2 Post By JonEisberg
post #1 of 5 Old 11-02-2014 Thread Starter
I've got two huge water tanks that fill up both my settees completely. Aside from not having any storage in the settee they are a PAIN to clean. While there are a few small access ports it's pretty hard to get your arm in there to clean them out.
What I'm thinking of doing is cutting a larger hole around the existing ports and putting in a couple of these
Any reason why NOT to do this? I can't imagine it would affect the structural integrity of the tanks.
CS 36M DIANTHUS
sailordave is offline
post #2 of 5 Old 11-02-2014
I've used them but found them difficult to seal completely. Of course that was 20yrs ago, they may have improved since then. The last time I was at the boatyard chandlery they had a very nifty access hatch that had a 1/4" or so flange that was tapped and threaded that fit inside the tank, a rubber gasket and a lid that bolted down on the outside. The lid had a very cool access port with a quick release lever similar to an old fashion milk canister or fire extinguisher. Didn't see a make or price but estimate about $150.
SJ34 is offline
post #3 of 5 Old 11-02-2014
baDumbumbum
bobmcgov's Avatar
Re: Water Tank access port
Those inspection ports work fine. We put two of them on our water tank. Bed them well, & use short #8 or similar machine screws with SS nylocks on the back. You don't want sharp screw heads gouging your forearm open. May want to periodically grease the O-rings (good ports have two) with silicone.
ETA: Use larger inspection plates, separate your tanks, and you can store things in one or both of them. We may keep vacuum-packed dry goods in our tank when cruising where water is easily found.
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
post #4 of 5 Old 11-02-2014
I agree, they're great... I'd suggest getting the ones with the clear cover, however, makes it very simple to monitor your water level...
And get a set of spare gaskets from Beckson if you're going off somewhere, they can be a bit difficult to find...
Faster and Rhapsody-NS27 like this.
JonEisberg is offline
post #5 of 5 Old 11-02-2014 Thread Starter
EXACTLY what I was planning on doing. I didn't want to distract from the original purpose of the thread by digressing. I'll probably just fill it with bottles of water; prevents contamination, easier to handle, etc. For extended cruising would fill one tank for washing and use the other for storage.
I had originally thought about cutting one of the tanks open all across the top, but leaving the body of the tank there and keeping my tools and other heavy objects in it so they'd stay dry and contained. I'll probably NOT do that only because I don't want to screw up resale value.
Yeah, used a smaller version of these on my old Laser. And no, you don't want to rip open your arm.
CS 36M DIANTHUS
Water tank access cover leak brokesailor Gear & Maintenance 2 08-14-2011 07:21 PM
PSC 37 Water Tank Access Ports: An Update BirdBrain333 Pacific Seacraft 4 08-07-2011 07:07 AM
how to open water tank inspection port rmeador Gear & Maintenance 19 10-27-2010 09:32 AM
Diesel tank access port question Pub911 Gear & Maintenance 4 01-07-2008 05:33 PM
Islander 32 Port Water Tank dheisman Islander 0 01-20-2007 01:30 PM
