propane furnace opinions please - Page 2 - SailNet Community
 16Likes
post #11 of 31 Old 11-25-2014 Thread Starter
islander bahama 24
newhaul's Avatar
Re: propane furnace opinions please
Thanks for all the input I guess I forgot to include the part about this being for the new to us boat a 42 ft Spencer built in Canada and well insulated also already have propane on board with two 30 pound tanks. Also I worked HVAC for many years on houses and am a retired shipwright the unit in question was priced at just about 1500 for install kit as opposed to the wabasco diesel unit at just under 3 k. I just have never installed one on a boat and dad doesn't want a bulkhead unit has to be forced air also what would the units do to the potential resale value would the diesel increase the value enough to offset the install cost any
Illegitimus Non Tatum Carborundum.
newhaul is offline
post #12 of 31 Old 11-25-2014
midnightsailor's Avatar
I would heartily recommend the Dickenson Propane unit . It comes in two sizes ,the larger ,which have puts out 12,000BTU on high. It heats my Freedom 33 with now problem, the unit also has a fan that is adjustable and helps distribute the heat. I generally run on high untill boat warms up(about 15-20 minutes ) then turn it down to maintain heat. While I agree that propane has a low energy densiity these units are quite efficient and my two 6 lbs run my hot water and stove too yet Ive never felt like I didingt have enough propane. I live aboard and run the unnit continuosly when aboard and I have to switch tanks about once every weeks. Im adding a deck mounted 20 lb barbecue size just for the winter so that should last atleast a month.
The other real nice thing is the "AMBIENCE" it is truly wonderful too curl up next to the "fireplace" with a book and a cup of Pete's Coffee !!
Rhapsody-NS27 likes this.
midnightsailor is offline
post #13 of 31 Old 11-25-2014
mitiempo's Avatar
The Dickinson P9000 or P12000 are good safe units for boats but not great for liveaboard boats. Their fan is hardly able to distribute heat to a V-berth or after cabin.
The best units would be forced air from Wallas, Espar, or Webasto with the Wallas being the quiet one. All 3 are thermostat controlled forced air furnaces suitable for a boat of 42'. Call Scanmarine in Seattle for your options. If the budget is higher look at a hydronic system from Espar but expect 8 - 10k pricing.
jrd22 likes this.
Brian
mitiempo is offline
post #14 of 31 Old 11-25-2014 Thread Starter
islander bahama 24
newhaul's Avatar
Brian the budget is rather limited right now just bought new technotics holding plate freezer and refer unit likely will do a Wallis but may not be able to afford it until next summer before going to Alaskan waters and the bulkhead units are not possible we would either loose part of dinette and that berth or loose the two sea berths on the port side and that is not an option so forced air is the best way to go.
newhaul is offline
post #15 of 31 Old 11-25-2014
mitiempo's Avatar
Originally Posted by newhaul View Post
.....so forced air is the best way to go.
For a Spencer 42 I agree.
Brian
mitiempo is offline
post #16 of 31 Old 11-25-2014
Courtney the Dancer
jrd22's Avatar
Our Wallas forced air furnace does a great job in our 40' pilothouse. Just spent three days in sub freezing temps and it was toasty warm. You won't regret going the diesel forced air route if you are going to use the boat in cold weather (or even in warm weather/ cold water). Scanmarine is great to work with for DIY installation.
mitiempo likes this.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #17 of 31 Old 11-26-2014
pdqaltair's Avatar
Yup, a Cal and and a Spencer 42 are a little different. Minor details.
Diesel forced air.
pdqaltair is online now
post #18 of 31 Old 11-26-2014 Thread Starter
islander bahama 24
newhaul's Avatar
Diesel forced air.
Im not getting itif you are referring to the confusion concerning boats I own and live on an islander Bahama 24 the Spencer is my dads new boat I have a force ten propane unit on my boat we are needing non electric heating for the 42 right now he is heating with a forced air 110 ac and a 110 ac radiant unit the po before the kid we got the boat from removed the original heating plant for some reason not sure what that was dad is the 5th owner
newhaul is offline
post #19 of 31 Old 11-27-2014
Newhaul.. it wasn't totally clear, to me, anyway, that we were talking about your Dad's boat at first. Like most, probably, I saw your avatar and made assumptions
Seems the consensus for a boat that size, is diesel forced air (or diesel hydronic). Not the least expensive options but if you go the 'truck source' route I think you can do pretty well comparatively speaking.
An old-school diesel stove/bulkhead heater would probably do a good job of heating the main cabin but warming the ends of the boat would become an issue, I think.
I don't think a 'inexpensive' propane fired unit that the insurance company might balk at is the final answer.
Faster is offline
post #20 of 31 Old 11-27-2014
Dirt Free
boatpoker's Avatar
Forced air unit ? How about this natural gas furnace run off two 20lb. propane tanks. I love my job, I get to see stuff like this every day
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
An old gravity fed propane furnace from camper installed on boat-good idea or bad islandskim Cruising & Liveaboard Forum 25 01-24-2013 08:14 AM
Propane santana30RI Gear & Maintenance 41 02-16-2012 10:06 AM
Dickinson newport propane heater opinions ? jbrockpiano Gear & Maintenance 4 11-19-2010 03:06 PM
Propane davidpm Gear & Maintenance 38 12-07-2008 10:44 PM
