Toilets, Y valve or not Y valve - Page 3 - SailNet Community
 6Likes
post #21 of 44 Old 12-22-2015
Mermaid Hunter
SVAuspicious's Avatar
Re: Toilets, Y valve or not Y valve
Originally Posted by VIKINGBEAR View Post
In process of rebuilding plumbing system on my 31’ sailboat.
From your description and follow up posts I believe your plan will be just fine.
You can meet the requirement for avoiding overboard discharge by putting a key-operated inline electrical switch in the line to the macerator pump.
SVAuspicious is offline
post #22 of 44 Old 12-22-2015
mitiempo's Avatar
Or just tie-wrap the valve closed as allowed by the Coast Guard.
Brian
mitiempo is offline
post #23 of 44 Old 12-22-2015
Mermaid Hunter
From the OP description there is no Y valve. An electrical disconnect is fine.
post #24 of 44 Old 12-22-2015
mitiempo's Avatar
It is, if more complicated than necessary. The seacock can be tied closed which is a bit simpler.
Brian
mitiempo is offline
post #25 of 44 Old 12-22-2015
Argyle38's Avatar
Dock
Originally Posted by TomMaine View Post
And we're used to discharge laws on the great lakes so I know from experience, my set up would not pass-you have to have NO ability the pump overboard-none, in fresh water no discharge areas.
Is this true on the US side of the great lakes? I don't believe it is, unless it's a new law. I've heard these are the rules in Canada, but not in the US. Wasn't able to find any reference to this. Do you have a link or a quote from the EPA, USCG, Boat US or something similar?
S/V Argyle
Downeaster 38 #40
Argyle38 is offline
post #26 of 44 Old 12-22-2015
Master Mariner
capta's Avatar
So what you are saying is that any vessel that visits the Great Lakes must first haul out and remove and plug any seacocks that were legally in use in other places, before sailing the Great Lakes? Hum, I guess we'll just pass on visiting the Great Lakes.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #27 of 44 Old 12-23-2015
Old soul
MikeOReilly's Avatar
If there really is such a law I've never heard of it being enforced in Canada. I've cruise the Great Lakes for over ten years. A few of those was with a Y valve setup. I simply tied off the valve with a tiewrap. In all my years on the Lakes have never even had any police even ask about my setup, let alone inspect.
Why go fast, when you can go slow
Why go fast, when you can go slow.
BLOG:
MikeOReilly is online now
post #28 of 44 Old 12-23-2015
Tanski's Avatar
Appendix 2.0 Sewage Holding Tank Systems - Transport Canada
"Information Note:
Ontario Waters
For pleasure craft in the waters of Ontario, the overboard discharge is not permitted as per the Environmental Protection Act (Ontario), Regulation 343, “Discharge of Sewage from Pleasure Boats.” Any overboard discharge, as shown in options 2, 3 and 4 will have to be disconnected and blanked before entering the waters of Ontario."
As Mike said I have never heard of it being enforced but it is the law......
Tanski is offline
post #29 of 44 Old 12-23-2015
JimsCAL's Avatar
But where does your head empty into the tank?
All I really am saying is, a "T" can replace a Y valve, in most instances. As both the overboard discharge, and the deck outlet have to drain-suction from the bottom(or top with standpipe), they can be combined via a "T".
This means the Deck plate and the hand pump operate as shut offs-when pumping overboard or pump-out(hope this makes sense ) In my case, a Y valve was redundant, expensive, tedious and stinky.
The other 1 1/2" tank outlet-top, will be the in-flow from the head pump.
I agree with this. When the Y-valve on the outlet of holding tank froze and the plastic handle broke, I replaced it with a tee. As Tom states, the pumpout cap and the overboard pump and seacock act as shutoffs. More reliable and simplier. My bladder tank does have a vent however. Hated the badder tank on my previous boat but this one works fine.
JimsCAL is online now
post #30 of 44 Old 12-23-2015 Thread Starter
I took out the Y and the Y valve in March this year, and installed new hoses without any T or Y or Y-valves. One hose from head to top of holding tank, Two outlets in the bottom of holding tanks, one to the macerator/seacock via vented loop and the other to deck pump out. The simplest system in my opinion. Handle on seacock always closed (not locked or zip-tied) when sailing in NDZ and keyed switch on the macerator pump with key stored in the cockpit on the key chain together with the engine starter key.
All perfectly legal and no smelling standing sewage in any of the hoses, T's, Y's or valves anymore.
All I can say is: "why did I not think of this before"?
VIKINGBEAR is offline
Tags
discharge , marine toilet , plumbing , waste tank installation , y valve
Joker valve? deniseO30 Gear & Maintenance 11 06-25-2013 06:03 PM
dinghy valve help lans0012 General Discussion (sailing related) 0 05-06-2013 12:04 AM
Propane valve davidpm Gear & Maintenance 26 04-01-2012 08:17 PM
Fuel Valve HorizonHunter Gear & Maintenance 8 02-05-2010 05:39 PM
Replacing SeaCock Gate Valve with Marine Ball Valve saurav16 Gear & Maintenance 30 06-15-2007 10:52 PM
