Bottom of hull rudder post issue - SailNet Community
post #1 of 1 Old 03-08-2015 Thread Starter
George Da Porge's Avatar
Iím getting a new rudder for our Catalina 30. In the process, I looked very close at the bottom of the hull/rudder post. See the attached pics. The surface at the bottom of the post is not flat. It rises toward the stern. From all appearances this is how the boat was built. The new rudder will have a thrust washer at this location, as did the other rudder. Is this non-contact area something to be concerned about and corrected? I will be repairing the cracks you can see around the post. Note: The piece of wood in the one pic isnít really square to anything Ė I used it as a reference to a straight surface.
Any comments appreciated! I will be on the road for the next week or so, so if I donít reply to a post right away, thatís why. Thanks!
George Da Porge is offline
How bad is this bottom issue (photo) MedSailor Gear & Maintenance 24 04-22-2014 03:10 PM
Compression post issue sailho Islander 16 08-23-2012 11:05 PM
Hull Issue - Need Opinions AboardIndigo Gear & Maintenance 20 08-29-2007 08:43 AM
CAL39 Hull Flange Issue MarkHorowitz Cal 0 06-27-2007 02:51 PM
Rudder issue 27 catalina jybiom Gear & Maintenance 1 07-12-2004 07:35 AM
