C-lark 14 traveller repair - SailNet Community
post #1 of 13 Old 04-25-2015 Thread Starter
blackflagsailor's Avatar
Question C-lark 14 traveller repair
Hello all! I have been absent on here for a long while. Last year I had changed jobs and my new position sadly didn't allow for much free time...
Anyway, I don't think the traveller rig on my C-Lark will make it through the season. The eye straps are stretched out and the fiber glass is pulled up at the screw holes. The setup is pretty simple. A length of covered steel cable is run through some thimbles and crimped at each end. The loops are hooked through steel eye straps, bolted to the hull. A swivel block travels along the covered steel rope. Pretty simple.
So the easiest fix would be to just replace the eye straps. No problem. However, could this setup be improved since I will have to replace it? Is there a way to save the fiberglass from all the stress being pulled on it?
Or perhaps it's not the hardware but rather in my sailing? In which case, maybe someone could offer some advice?
blackflagsailor is offline
post #2 of 13 Old 04-26-2015
Lake Superior Sailor's Avatar
Re: C-lark 14 traveller repair
Got pictures? A lot depends on the room you have and the money you want to spend!...Welcome back! Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #3 of 13 Old 04-26-2015 Thread Starter
Nice profile pic! Cheers!
I disassembled it last year but here are a few pics of the eye straps on the top side.
Most of the original hardware is still on the boat and was made by Racelite. here is one of their diagrams with the same traveler setup I have.
Racelite rigging diagram
post #4 of 13 Old 04-26-2015
celenoglu's Avatar
Pictures will help a lot. Since the eye straps are streched out, the bolts do not have backing plates or they are not big or thick enough to hold the eye straps.
celenoglu is online now
post #5 of 13 Old 04-26-2015 Thread Starter
No backing plates. Just some stainless machine screws possibly and washers. It always bothered me. Last time I took her out the eye straps stretched out. I've been looking into ways of improving and strengthening this but I'm not really sure on best way to do this.
post #6 of 13 Old 04-26-2015
celenoglu's Avatar
This connection is surprisingly poor. The washers are located on top and they are a lot bigger than the screws. The load should be properly distributed to the fiberglass with backing plates. You will also need proper sized washers on top and the bottom.
post #7 of 13 Old 04-26-2015
tomhuntdmd's Avatar
You need to head over to Fisheries or West Marine and pick up a dropped forged eye strap of the same size. Those stamped ones are too weak for the job.
http://http://www.fisheriessupply.com/wichard-eye-strap
As for backing, you could use large SS fender washers with a smaller washer stacked on top, but better would be a piece of SS or aluminum. I was able to purchase a piece of 1/4' Al at my local True Value hardware store pretty reasonably.
As for the traveler wire, do you still have the double pulley as shown on the spec sheet? You might want to consider a piece of Dyneema instead. Quieter, runs smoother, and won't scratch your fiberglass. I used to have a similar arrangement on an O'day Javelin many years ago
tomhuntdmd is offline
post #8 of 13 Old 04-26-2015 Thread Starter
I have all the components still. I shall have to check out good o' Fisheries when I'm in Seattle next.
I was going through my photos and I did find one of the traveler a few years ago.
post #9 of 13 Old 04-27-2015
I suspect you're tugging way too hard on the mainsheet, in an effort to drive the boat to windward an extra 32nd of a degree. There's a point of diminishing returns, where you get an insignificant amount of benefit for the added load that you put on the gear. The C-Lark isn't designed to withstand the kinds of loads that you would put on a bigger, ballasted boat. I'd put backing plates behind the attachments, and ease up on the mainsheet.
Sailormon6 is offline
post #10 of 13 Old 03-30-2020
@blackflagsailor - We live in Seattle area also. Just wondering if you have any interest in selling your yellow C-lark?? Hopefully you will see this post. Sailnet wants me to make 20 posts before I can send you email!!
DuffyN is offline
C-Lark Spinnaker blackflagsailor General Discussion (sailing related) 14 04-03-2020 08:38 PM
C-Lark Standing and Running Rigging mgerdau Gear & Maintenance 0 11-21-2014 12:13 AM
c-lark rigging Sherry Other Brands 19 06-28-2014 11:10 AM
Fixable? advice on damage to an old lark... mvy18 Boat Review and Purchase Forum 3 03-06-2011 09:05 PM
Traveller Car Repair rlincoln Gear & Maintenance 0 02-15-2002 08:13 AM
