Question about spreader/rigging geometry - SailNet Community
 8Likes
post #1 of 31 Old 06-15-2015 Thread Starter
__floater__'s Avatar
Question Question about spreader/rigging geometry
My 27 foot sloop is a 7/8 (approximately) fractional rig with the swept spreaders normally associated with a fractional rig. The spreaders themselves have a wing-like profile which "plug" into a matching receptacle which is rivited to the mast. The shrouds pass through slots under the outer end caps of the spreaders.
While ascending the mast Saturday to repair a windex that was damaged in branches during launch, I noticed the spreaders are "bending" downward. This came as no surprise to me because I always considered the geometry of sailboat rigs to be flawed at the spreaders.
My question is, why are spreaders configured to be perpendicular to the mast (where they are already securely fastened) and not to the shrouds (where the spreaders can slip down the wire by the forces of the load)?
If the spreader were angled up to become perpendicular to the shroud, the load would be transfered to the mast more effeciently. I just never understood this geometry.
I asked a rigger of 26 years about the situation and he had no answer.
SV Whisper
1981 Aloha 8.2
Hull #50
__floater__ is offline
post #2 of 31 Old 06-15-2015
Master Mariner
capta's Avatar
Re: Question about spreader/rigging geometry
On a single spreader rig such as yours, the shroud changes direction at the spreader. Where exactly in this change of direction or angle, would you expect this perpendicular angle?
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #3 of 31 Old 06-15-2015
Load Bearing Member
CarbonSink62's Avatar
Dock
I would expect that splitting the difference between the 2 angles would create a situation where the spreaders wouldn't want to move down at the outboard side.
Ken
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
post #4 of 31 Old 06-15-2015
Ken
That's the trick.. there should be enough give in the spreader root to create a spreader angle that bisects the shroud angle. That way there's no tendency for the spreader tip to slide up or down due to forces from the shroud itself. Not a bad idea to wire/clamp the spreader in position too, as in some cases as the leeward shroud slacks in a breeze and lump they can move about some.
Markwesti likes this.
Faster is offline
post #5 of 31 Old 06-15-2015
Barquito
Barquito's Avatar
I think Floater is saying that the two angles are not equal. Same on my boat. The spreaders are perpendicular to the mast, therefore, they bisect the shroud forming a more acute angle on the top than on the bottom. Seems like this would put pressure on the spreader to move down at the shroud.
__floater__ likes this.
Valiant 32
Barquito is offline
post #6 of 31 Old 06-15-2015 Thread Starter
Exactly.
If the spreaders were 90 degrees to the shroud, the load would be transfered straight back through the spreader, causing no force either up or down. It would however create a downward force at the base of the spreader where it meets the mast, but this would be of no concern because of the strong mechanical connection made at the spreader/mast.
Maybe I don't understand transfer of loads as well as I think I do, but having a "loose" connection on something that is at an angle is just looking for trouble IMO.
The owner who had my boat before me had stainless steel saddle clamps on the shrouds beneath (actually touching) the spreaders. I didn't like the ideal of pinching the shrouds and I'd never seen it done before so I removed them. Maybe I'll have to put them back!
SV Whisper
1981 Aloha 8.2
Hull #50
post #7 of 31 Old 06-15-2015 Thread Starter
As I said in the post above, I don't like to clamp a shroud. Maybe it doesn't hurt but it seems wrong to me.
What I am considering though is "assistant uppers" that would fasten a few inches below where the uppers terminate at the mast and a couple inches in from the end of the spreader, which would hold the spreaders up.
SV Whisper
1981 Aloha 8.2
Hull #50
post #8 of 31 Old 06-15-2015
Our spreaders have a clamp bracket built into the ends..
C&C did this on their late 70's/early 80s 34.
Faster is offline
post #9 of 31 Old 06-15-2015
overbored's Avatar
first there is no normal for a fractional rig. there any number of ways it has been done. most new modern rigs have the spreader angled up at about the intersect angle of the shrouds. some are perpendicular to the mast. the ones I have seen that angle down are because the fittings are bending down over time and were most likely perpendicular when new. the newer masts have a carry thru solid spar that the spreader slides over and is thru bolted.
if they are angled down I would take a closer look at the attachments as the may be bent or they have been installed upside down. I have seen this on a sparcraft mast where the owner did not know and installed the carry thur and the spreaders upside down. we set him straight at the yard as they were rigging the boat
"GOLD RUSH" PRINDLE 16
overbored is online now
post #10 of 31 Old 06-15-2015
Markwesti's Avatar
This is a interesting thread . On our boat the spreaders float a little at mast where they connect and angle up a couple of degrees . One time , along time ago one spreader sagged a bit I just shoved it back up and it never did it again . We also have the extra shrouds that start about 2" from the tip of the spreaders and attach about 3' above the spreaders . I asked the guy that used to run the Westsail factory what they were for , he said "they are there support for when you are standing on a spreader trying to see over the horizon" .
Markwesti is online now
Extra spreader question Swordhors Gear & Maintenance 3 12-19-2012 01:54 PM
Spreader question Stevyboy Gear & Maintenance 7 02-09-2011 09:25 PM
Variable Geometry Wing Sails VGWS1 Introduce Yourself 8 01-25-2011 06:40 PM
Mast Standing Rigging Spreader Replacement. sce56 Gear & Maintenance 2 05-08-2009 11:12 PM
yet another spreader question Gorlog Gear & Maintenance 3 04-27-2007 10:51 PM
