Bene First 285 - SailNet Community
post #1 of 4 Old 06-17-2015 Thread Starter
davidpm's Avatar
Bene First 285
This picture shows the switches for the batteries.
I'm used to the 1 ,2, all, off switch.
Do these switches have two off positions in that you can turn them off either right or left?
davidpm is offline
post #2 of 4 Old 06-17-2015
Re: Bene First 285
Yes, I have a switch like that on the starter circuit. It turn either way.
"...there are two kinds of opinions, those based upon tradition ... and those having something in their favor." B. Russell
aloof is offline
The Following User Says Thank You to aloof For This Useful Post:
davidpm (06-17-2015)
post #3 of 4 Old 06-17-2015
mitiempo's Avatar
Re: Bene First 285
Beneteau switches are usually just on/off. Look behind them - if there are just 2 connections they are only on/off.
The normal arrangement is house on/off, start on/off, and negative on/off.
Brian
mitiempo is offline
The Following User Says Thank You to mitiempo For This Useful Post:
post #4 of 4 Old 06-17-2015
Re: Bene First 285
Correct, it doesn't matter which direction you turn them. Vertical is on and horizontal is off.
Jeanneau 54DS
Minnewaska is offline
The Following User Says Thank You to Minnewaska For This Useful Post:
Bene First 285 got hit davidpm Gear & Maintenance 27 06-20-2015 12:52 AM
J or Bene? fishpants Boat Review and Purchase Forum 31 04-07-2015 09:47 AM
Before and after - Bene F26 afrinus Gear & Maintenance 1 06-16-2012 09:40 PM
Bene vs Catalina? jorgenl Boat Review and Purchase Forum 73 08-26-2010 03:13 PM
Bene 31 vs Hunter 33 bacampbe Boat Review and Purchase Forum 60 04-10-2009 03:48 PM
