Applying Cetol Natural Marine Teak - SailNet Community
post #1 of 8 Old 06-27-2015 Thread Starter
S/V "MACKINAC"
The PO of my Pearson 35 used Cetol on the teak. Overall "most" of the Cetol has held up. There are some places that the Cetol has peeled a bit. Do i have to sand ALL the teak to reapply Cetol or can i just sand the "bad spots" and apply Cetol over the entire section to be painted.
Thanks
Bill
Maine_bill is offline
The Following User Says Thank You to Maine_bill For This Useful Post:
Rksailsolo (06-27-2015)
post #2 of 8 Old 06-27-2015
Markwesti's Avatar
Re: Applying Cetol Natural Marine Teak
I use Cetol light . My friend just finished a job with the natural . If you know for sure that you have natural then I would say yes concentrate on the real bad spots and paint them (2 coats) with Cetol and then sand the entire , and then one coat . I do that , I call it my patch job .
Markwesti is offline
The Following User Says Thank You to Markwesti For This Useful Post:
post #3 of 8 Old 06-27-2015
I've never had much luck in making a patch repair to the cetol. Last year I decided to enlarge the repair area by removing much of the good cetol and starting fresh. I applied 3 coats of the natural and then 2 coats of the gloss. I also applied a maintenance gloss coat to the adjacent area that joined the repair area. There was quite a bit of contrast between the two areas, however this year the contrast is not as great and it has turned out better than just making a small area repair even if it is more work.
lancelot9898 is offline
post #4 of 8 Old 06-27-2015
JimsCAL's Avatar
If its only a few spots, that should work. I would scape then sand sand the bad spots followed by a coat or two on the bare areas. Then a light sand on everything followed by a coat on everything.
JimsCAL is offline
post #5 of 8 Old 06-27-2015
Tanley's Avatar
It's worth a shot, have had mixed success myself. And that's assuming this is only for small touch up areas, not anything major. Take it back well into the 'good' finish and follow JimsCal's instructions making sure to scuff up the coats on the mating finish. Do you know if the PO put a gloss coat on top of the Natural Marine? I do 3 + 3 or 4, and it makes maintenance much easier as the gloss takes the abuse and requires refinishing.
Tanley is offline
post #6 of 8 Old 06-28-2015
RichH's Avatar
Pearson mostly used Iroko instead of teak. Iroko is a actually a most beautiful soft wood; and, is now an endangered species (?) and is next to impossible to find when replacing.
The best treatment for Iroko, which doesnt 'hold' most coatings, is usually oil finishes .... or heavy/many coatings of 'resinated' (varnish added) oil finishes which are applied like varnish and not wiped. Downside with oil coatings is that they dont last very long if not applied 'thick', and they do eventually turn very dark, and when applied 'thick' they take a long time to 'cure'. The worst feature of Iroko is that unless protected by coatings with 'heavy' UV filters, it is easily and deeply damaged by UV.
Oil finishes are easily removed by soaking with triSodiumPhosphate-TSP.
MaryKate Nu-Teak Oil
RichH is offline
post #7 of 8 Old 06-30-2015
The second time around with Cetol results in a mostly boring brown paint like finish. If you want any wood look at all you need to sand it down. Fortunately a Cetol finish is easy to sand off.
"...there are two kinds of opinions, those based upon tradition ... and those having something in their favor." B. Russell
aloof is offline
post #8 of 8 Old 06-30-2015
Wish I never found SN!
SimonV's Avatar
Just leave it alone and let it weather off. Then take the cento, throw it in the bin and enjoy the natural silver of weathers teak. It will last longer and work better, go sailing.
Simon
Bavaria 50 Cruiser
Mediterranean
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
Direct sunlight and applying varnish, oil, cetol RossC32 Gear & Maintenance 11 08-08-2014 08:24 PM
Applying Cetol jackytdunaway Gear & Maintenance 3 06-30-2009 01:11 PM
Cetol on Teak Shack Gear & Maintenance 59 05-14-2009 03:07 PM
Sikkens-Cetol Marine Natural Teak? BigMoe Gear & Maintenance 12 05-05-2009 10:40 AM
natural teak dm567 Gear & Maintenance 43 12-31-2006 06:41 PM
