We just cannot get it apart - Page 3 - SailNet Community
 14Likes
post #21 of 42 Old 07-07-2015
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Re: We just cannot get it apart
Originally Posted by desert rat View Post
If it still will not come apart. Take it off the boat and to a machine shop and have them vat it. Caustic soda will disolve anything except metal. You will need new springs, O-rings, gasgets, may haps even roller bearings, but it should come apart.
I think that's the point. They ARE trying to get it off the boat first.
Skipper Jer likes this.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #22 of 42 Old 07-07-2015
I believe that the gold stuff is Copper Grease, which I used to swear by in the UK when every fastener on a car would otherwise sieze solid in less than a year, due to the constant onslaught of water and salt. Aluminium to steel joints were particularly problematic. In California I still use it but the need is not so great.
MarkSF is offline
post #23 of 42 Old 07-07-2015
How 'bout something like a concrete stinger vibrator:
3/4 HP Concrete Vibrator
jongleur is offline
post #24 of 42 Old 07-07-2015
Sometimes you've just got to say "No more Mr Nice Guy"
Drill a hole right through the shaft. Insert a long bolt. Apply upwards pressure on the bolt (hit with lump hammer upwards), while applying constant pressure (line around the bolt, pull on it with the main halyard). I bet it will come off.
I also think there might be scope to clamp a bearing puller under the grooved part of the shaft, and then proceed as above.
MarkSF is offline
post #25 of 42 Old 07-07-2015
HANUMAN
RobGallagher's Avatar
You could try Kroil
Google Deal
I believe it to be the best stuff out there.
WINDHOVER
1999 CATALINA 36 MKII
NOANK, CT
RobGallagher is online now
post #26 of 42 Old 07-07-2015
Closet Powerboater
MedSailor's Avatar
I agree an impact wrench is in order. As much heat as you can apply as well. Also you could try Coca-Cola on the rusty bits.
MedSailor
MedSailor is offline
post #27 of 42 Old 07-07-2015 Thread Starter
Master Mariner
capta's Avatar
Originally Posted by Lake Superior Sailor View Post
Sounds a little over played! Scrap them, really glued together with epoxy? $ 8000.00? Try old junk!..Not even self tailing!..... Who needs instructions to take apart and service a winch?.....Dale
I'll tell you what, Dale. You guaranty to get both winches apart without destroying anything and I'll fly you down to do the job. LOL
Of course if you fail, instructions or not, and you screw up a couple of 8k winches that work just fine, you can replace them at YOUR expense. Should I book the ticket today?
And yes, epoxy, and some elbow grease. Check out the two pics below.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #28 of 42 Old 07-07-2015 Thread Starter
Master Mariner
capta's Avatar
Originally Posted by wfish11 View Post
How about one of those high-speed vibrating tools. They come with a number of blades one of which is a thin scraper. I use the scraper to remove a lot of things on boats that nothing else will break loose. Just fire it up and shove it down where you've been pushing that putty knife. Mine's a Dremel Multi Max but I know Bosch makes a similar tool. It works with both the vibrating action and the heat it builds up locally from friction. Try it it may work.
EURIKA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks wfish. Had one onboard the whole time, but never thought of it. An hour with that tool and it just popped apart. You can bet it's going back together with lots of anti-seize! Funny, it doesn't look all that corroded. What a great glue that would make!
Sorry, Dale, no plane ticket to the Caribbean this week.
Thanks all for some really helpful suggestions.
fryewe, MedSailor, TQA and 3 others like this.
capta is online now
The Following User Says Thank You to capta For This Useful Post:
oysterman23 (07-08-2015)
post #29 of 42 Old 07-07-2015
Siamese's Avatar
Great to see a dilemma solved! Way to go Wfish11.
The power of Sailnet.
Siamese is online now
post #30 of 42 Old 07-07-2015
Senior Moment Member
SloopJonB's Avatar
Don't worry so much about slathering on the anti-seize, just service the things annually and they'll always be free.
SloopJonB is online now
