We just cannot get it apart - Page 4 - SailNet Community
 14Likes
post #31 of 42 Old 07-07-2015
jimrafford's Avatar
Re: We just cannot get it apart
Nice!
Jim
S/V Deja Vu
CS 40
jimrafford is offline
post #32 of 42 Old 07-07-2015
aeventyr60's Avatar
Originally Posted by capta View Post
EURIKA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thanks wfish. Had one onboard the whole time, but never thought of it. An hour with that tool and it just popped apart. You can bet it's going back together with lots of anti-seize! Funny, it doesn't look all that corroded. What a great glue that would make!
Sorry, Dale, no plane ticket to the Caribbean this week.
Thanks all for some really helpful suggestions.
Can you tell us more about this magic vibrating dragon slaying tool of yours? Pictures or a link to the product?
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is offline
post #33 of 42 Old 07-08-2015
Lake Superior Sailor's Avatar
What happened to the self reliant sailor? You had the tool on board and did not try it? Some sailors!....Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #34 of 42 Old 07-08-2015
RichH's Avatar
Capta .... when you put this back together and to prevent the problem in the future, consider to apply a liberal coating of "NOALOX". Noalox is 'the machinists' standard for corrosion prevention of especially aluminum and 'red metals' (which contain a few % of aluminum).
Amazon.com: Noalox® Anti-oxidant Compound (4 Oz. Bottle): Home Improvement
RichH is offline
The Following User Says Thank You to RichH For This Useful Post:
capta (07-09-2015)
post #35 of 42 Old 07-08-2015
aeventyr60: The original:
FEIN MultiMaster Start Q MultiMaster - Best.-Nr. 72294264090 - FEIN Power Tools Inc.
Many, many others now. All the way from Dremel to cheap Chinese knock-offs.
It is The Freakin Tool to have when you need to do what it does. The scraper is extremely useful. It is fantastic for undercutting door trims and jambs when installing hardwood flooring (in a non-floating house)
capta and aeventyr60 like this.
gptyk is offline
The Following User Says Thank You to gptyk For This Useful Post:
capta (07-09-2015)
post #36 of 42 Old 07-08-2015
The scraper is also useful for separating things that have been glued on with 5200 such as cleats, lifeline bases, hand holds, etc. It not only cuts but the friction causes heat which softens the material. just be careful of the screw that holds the tool on as it can mar the finish on fiberglass or wood. I usually put a piece of tough tape over it if I'm working close to the material.
The retired Dr. next to me recommends anhydrous lanolin to keep parts from welding together. You can get it at a drugstore. I've started using it but I haven't had it on anything long enough to recommend.
Glad you got your parts disconnected.
wfish11 is offline
post #37 of 42 Old 07-08-2015
Anhydrous lanolin is also the best hand cream that you can get...
Bob142 is offline
post #38 of 42 Old 07-08-2015
Senior Moment Member
SloopJonB's Avatar
Lanolin is an old trick for the threads of turnbuckles and the like - it's as waterproof as it gets but it's sticky stuff.
SloopJonB is online now
post #39 of 42 Old 07-09-2015 Thread Starter
Master Mariner
capta's Avatar
Honestly, I feel like a dope. It is one of those incredibly useful tools, that sits in the locker for years, until the right sort of job comes up. But being a relatively new tool, all it's possibilities aren't always apparent.
The one we have is like the FEIN MultiMaster, mentioned by gptyk.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #40 of 42 Old 07-09-2015
Good to hear problem solved! .........Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
