Where did you route your furler line? - Page 2 - SailNet Community
post #11 of 16 Old 08-04-2015
JimsCAL's Avatar
Re: Where did you route your furler line?
The Harken installation instructions specifically recommend a ratcheting block. It controls the speed of unfurling and prevents wraps of the furling line in the drum.
JimsCAL is online now
post #12 of 16 Old 08-04-2015
ASA and PSIA Instructor
Originally Posted by L124C View Post
Correction, I previously had it running off a shroud, but changed it to the configuration in the pic. Works great (red arrows).
That setup sure looks like a tripping hazard to me. The common practice of running the line through fixtures on the stanchions has no downside other than the cost of the hardware and the upside of a clear deck. But no lifelines, that can make an interesting thread...
sailingfool is online now
post #13 of 16 Old 08-04-2015
al brazzi
The new Daysailers (Aileron and such) have no lifelines and sure they look pretty, and in theory you don't leave the cockpit but are they practical? You're right that would be a different discussion.
albrazzi is online now
post #14 of 16 Old 08-04-2015
L124C's Avatar
Originally Posted by albrazzi View Post
No Lifelines? I don't think I could move around on a boat like that. I don't always pull or grab onto them but its always a good balance point, plus a great routing for furler lines. But you don't have to worry about the boarding gate being in the wrong place.
Actually, I think you would be surprised to find how much easier it is to move around on a narrow boat without "lifelines". However....that's another subject (and a loaded one at that!). Search my posts for the story of why I removed them, if interested. Please don't de-rail this thread with the discussion.
The PO had the furler routed through 3 blocks mounted on the stanchions. I have it going directly through one and can bring it around the back of a winch (if needed) to furl it with ease, in even the strongest blow. Certainly don't need a ratchet block.
BTW, If you think that's a "tripping hazard", you might want to think twice before going forward on a small sailboat!
L124C is offline
post #15 of 16 Old 08-05-2015
JimsCAL's Avatar
I sail regularly on an Alerion 28 without lifelines. You still have to go forward to pick up the mooirng etc. and I don't like it.
post #16 of 16 Old 08-06-2015
The issue is not to think twice about doing something so routine as going forward on a small boat, but rather are think prudently about setting your boat up with an on-going and un-necessary hazard to an otherwise routine activity? It's your boat, set it up as pleases you, but dont expect sympathy after your significant other went overboard going forward some night to free a backed jib sheet .
Hopefully you are following the COB thread...
Continous line roller furler navyguy28 General Discussion (sailing related) 5 11-19-2013 10:58 PM
Pacific Seacraft 31 furler line wmjr Pacific Seacraft 2 09-06-2013 01:14 PM
Cam cleat for jib furler line? MarkSF Gear & Maintenance 11 07-25-2011 07:39 PM
Continuous Furler line overbored Gear & Maintenance 3 05-17-2011 05:44 PM
Propane line re-route Oday30 deniseO30 Gear & Maintenance 6 08-20-2007 10:01 PM
