Chasing down a persistent Porthole Leak - Page 2 - SailNet Community
 1Likes
post #11 of 14 Old 08-24-2015
Old enough to know better
Re: Chasing down a persistent Porthole Leak
If you pull any hardware you might want to read this:
https://www.sailnet.com/forums/gear-m...utyl-tape.html
It is a good primer on sealing deck hardware. Maine Sail is very knowledgeable, I don't know if his butyl tape is really that much better than others, but it is not expensive so you are getting a known quality for a reasonable price.
You might want to make a signature and put the brand/model and year of your boat in it. As someone may have the same boat and say something like "oh that is the forward most hand hold on the cabin top, always leaks" or some thing along those lines. Is that a late 70's Pearson?
miatapaul is offline
post #12 of 14 Old 08-25-2015
Smile Re: Chasing down a persistent Porthole Leak
"Buy some cake coloring or food dye
5 different colors if possible"
Whoa, Dude! A tie-dyed sailboat!
"Dave's not here man!"
hellosailor is offline
post #13 of 14 Old 08-25-2015
My port leaked right over the chart table. Drove me nuts! It ended up being the handrails. Yes, the water travels. Work from high to low when looking for leaks. If it turns out being the handrail, or the hatch. I would dig out any wet core and pot the holes with epoxy and re-drill. I haven't had a leak since doing that. Knock on fiberglass..
If the water is escaping through the port, that would also mean that you will likely have wet core along the path of travel. I ended up re-bedding my port as well. When they cut the opening for my port there were spots of raw core ends I dug out the wet core around the port and epoxied the edge. So that there was no raw core exposed. I picked a week of good weather and let everything dry out as much as possible before re-bedding everything.
tempest is online now
post #14 of 14 Old 08-25-2015
RichH's Avatar
Originally Posted by capta View Post
As mentioned above, your best approach to this is to completely redo the whole port.
However, keep in mind that the water may be coming in some place else (the hatch above the port?) and just channeling to this egress point. Water can move a long way inside a boat from point of entry to point of visible egress.
Its not uncommon for portlights near or directly under any 'fastener attached' device to drain water, the water getting into the core of the deck house from the leaking fasteners above. Loosened hand rails are notorious leakers and the water can indeed migrate a long way to the most vulnerable exit point. Best is to remove the porlight, inspect for water migration from other sources, etc. etc.
A rotted side of a coach roof core is a real PITA to remedy; in the northern areas where it freezes its easy to find a water soaked coach roof side - they often CRACK when the ice builds up sufficient pressure.
RichH is offline
Tags
leak , porthole , water
Porthole Rebed?? csharp56 Gear & Maintenance 4 02-11-2014 08:18 PM
Porthole. Re-build steenbn Gear & Maintenance 3 08-11-2012 09:53 AM
Porthole Question Alden68 General Discussion (sailing related) 2 04-28-2007 11:06 PM
Persistent or Oscillating: Answers @ Proper Course NewsReader News Feeds 0 04-14-2006 10:15 AM
Persistent or Oscillating @ Proper Course NewsReader News Feeds 0 04-13-2006 08:15 AM
