Sinking Feeling - Page 2 - SailNet Community
 12Likes
post #11 of 30 Old 08-25-2015
overbored's Avatar
Re: Sinking Feeling
Sinking will take a lot of the pleasure out of sail too. don't go off on us because you are to lazy to close them and did not expect a failure. the one thing that I have learned in 60 years of working on boats is to do everything you can to prevent a failure. if you don't turn them off then I say you should expect the next failure will be sooner then you think.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #12 of 30 Old 08-25-2015
Morild's Avatar
Re: Sinking Feeling
What about the drain(s) from the cockpit, do you close them as well, when you leave the boat?
Morild is online now
post #13 of 30 Old 08-25-2015
Re: Sinking Feeling
We always close all seacocks when leaving for more than a day. If you make it part of your normal leaving and returning routine you should not forget. (turn on engine battery, open engine seacock, etc...) It's worked for us.
CrystalClear is offline
post #14 of 30 Old 08-25-2015
Re: Sinking Feeling
According to Boat US, closed (or blocked) cockpit drains are the number one cause of boat sinkings in marinas. The cockpit fills up, and downfloods into the salon.
One nasty possibility is that the drains block, the weight of water in the cockpit is enough to lower the drains below sea level, then the boat sinks fast.
Rather than close the cockpit drains, the solution is to have components that you can rely on. I have the really thick Trident hose, double clamped at the through-hulls.
You also need to visit regularly and make sure they are not blocked.
SailsTax and Rhapsody-NS27 like this.
MarkSF is offline
post #15 of 30 Old 08-25-2015
scratchee's Avatar
Re: Sinking Feeling
I am very disciplined in this regard. Every time I sail, without fail, on the drive home I wonder if I should have closed the seacocks.
deniseO30 and Minnesail like this.
scratchee is online now
post #16 of 30 Old 08-25-2015
Re: Sinking Feeling
Originally Posted by MastUndSchotbruch View Post
As it happens, a few weeks ago I had the kitchen sink metal (connector under the sink) literally crumble in my hands when I was working on something down there. I could have failed literally any time and easily sunk the boat had the seacock been open.
I ALLWAYS close ALL seacocks when I am not on board.
This just emphasizes that you need to have all the critical components in good condition. Solid through-hulls, top-quality hose, double-clamped.
The Trident hose to my sinks is so stiff, it could disconnect from the sink and nothing would happen as the top end will always be above the water line.
Closing sea-cocks is fine, but that should be a failsafe, not a substitute for quality components and proper maintenance.
MarkSF is offline
post #17 of 30 Old 08-25-2015
Re: Sinking Feeling
Not sure if that was addressed to me.
In any case, it would not apply, my cockpit drains do not have seacocks. The corresponding thru hulls are under the stern and above the waterline (though only just).
MastUndSchotbruch is online now
post #18 of 30 Old 08-25-2015
Re: Sinking Feeling
I agree, that is exactly as I see it.
I did not think I would need to do preventive maintenance on a kitchen sink; failure of this part was not something that I expected. Of course now I know that this can happen but I assume that there may be other things that I do not expect to fail. Therefore I want redundancy. Therefore I close the seacocks.
post #19 of 30 Old 08-25-2015
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Re: Sinking Feeling
I had that happen to me last winter. We had heavy snow that blocked the drain in the cockpit then immediately followed by rain. Came to the boat and the bilge was full. And my boat is on a trailer.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is online now
post #20 of 30 Old 08-25-2015
rnixon's Avatar
Re: Sinking Feeling
Originally Posted by sailnman View Post
My reason for the post was to suggest people check their water stainer, not to start a dialog about closing seacocks. My failure was due to metal fatigue, something you normally wouldn't see unless you were looking for it.
Sorry, but your experience is a very good case for closing them, IMO. You may want to run the risk to save a time on each trip, but you could have lost your boat.
I don't own a boat (don't get to sail enough), but would go through a pre-cruise checklist before each outing even for my own boat. That would include the position of seacocks.
rnixon is offline
You and the Law: They rented the sailboat and got that sinking feeling - Hanford Sent NewsReader News Feeds 0 10-30-2013 07:30 PM
Labor Day Sinking Feeling itsaboat General Discussion (sailing related) 2 09-06-2012 02:58 AM
That sinking feeling GaryHLucas General Discussion (sailing related) 17 08-26-2012 09:55 PM
That sinking feeling. PSS. SimonV Gear & Maintenance 18 04-08-2008 08:54 AM
Sailing: Movistar get that sinking feeling (Guardian Unlimited) NewsReader News Feeds 0 05-22-2006 12:15 AM
