Sinking Feeling - Page 3 - SailNet Community
 12Likes
post #21 of 30 Old 08-25-2015
Group9's Avatar
Re: Sinking Feeling
My feeling is that seacocks are there for a reason. I couldn't sleep at night, away from my boat, knowing any of my sea cocks were open (and I have a lot of them) after having seen so many boat sink because a hose spit or blew off and overwhelmed the bilge pump before anyone noticed.
Group9 is offline
post #22 of 30 Old 08-25-2015
Group9's Avatar
Re: Sinking Feeling
Originally Posted by Morild View Post
What about the drain(s) from the cockpit, do you close them as well, when you leave the boat?
I have an open transom, so I don't have cockpit drains so to speak. Just one huge one in the back!
On the northern Gulf of Mexico.
"Best thing to do is get her out on the ocean. If anything's gonna happen, it's gonna happen out there." Captain Ron Rico
Group9 is offline
post #23 of 30 Old 08-25-2015
JimsCAL's Avatar
Re: Sinking Feeling
Originally Posted by MastUndSchotbruch View Post
As it happens, a few weeks ago I had the kitchen sink metal (connector under the sink) literally crumble in my hands when I was working on something down there. I could have failed literally any time and easily sunk the boat had the seacock been open.
A friend almost lost his boat years ago with a similar issue. Sink hose slipped off the sink connector, fell down, and water started running in. Luckily he noticed the boat was low in the water before it sank.
JimsCAL is online now
post #24 of 30 Old 08-25-2015
Master Mariner
capta's Avatar
Re: Sinking Feeling
I believe the problem lies more with the deterioration of the cork gasket on the sea strainer than the bronze. As the cork deteriorates, one must tighten the wing nuts more and more, thereby putting much more pressure on the bronze, rather than compressing the cork. I rarely need to tighten that type of sea strainer more than hand tight, plus a bit.
Again, a maintenance failure, not an equipment failure.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #25 of 30 Old 08-25-2015
Re: Sinking Feeling
So common is the crumbled sink bib. And a hose held up by it. Everyone should get under their sink to see how close to sinking they are.
Capt Len is online now
post #26 of 30 Old 08-26-2015
Re: Sinking Feeling
If you use proper hose, the Trident (or similar) stuff with the thick wall, it is more likely to hold the sink up, than be held up by it. It won't "fall down".
MarkSF is offline
post #27 of 30 Old 08-26-2015
Re: Sinking Feeling
Of, forget about seacocks. That's for cheapskates.
The prudent mariner drysails his yacht. And has the marina staff pull it, block it, and secure it with hurricane ties whenever it is not being used. We usually call ahead and have it relaunched first thing in the morning before taking it out again.
Seacocks. Wet storage. Really? Is money so tight?
Morild likes this.
hellosailor is offline
post #28 of 30 Old 08-26-2015
Re: Sinking Feeling
And you want to rely on a hose holding the sink up, rather than closing the seacock?
You are a braver man than I am.
MastUndSchotbruch is online now
post #29 of 30 Old 08-26-2015
Barquito
Barquito's Avatar
Re: Sinking Feeling
Good point. Most cockpit drains will only have one hose/seacock per drain, whereas, the engine seacock will have many connections and components that can fail... the strainer being one. Therefore, you will decrease risk the most my leaving drains open, and everything else closed.
As to the OP. He gives good advice. Check everthing that is under the water line often.
MarkSF likes this.
Valiant 32
Barquito is offline
post #30 of 30 Old 08-26-2015
Over Hill Sailing Club
smurphny's Avatar
Re: Sinking Feeling
If you're leaving the boat for any extended period of time, then closing everything off is a good idea but to do that every time you leave for a day or two just ain't going to happen. The best insurance is to have everything shipshape. Hoses aren't coming off and pieces aren't failing unless they're some sort of plastic junk or have not been maintained and checked once in a while. Most boat sinkings I've seen are the result of inattention.
MarkSF likes this.
smurphny is offline
You and the Law: They rented the sailboat and got that sinking feeling - Hanford Sent NewsReader News Feeds 0 10-30-2013 06:30 PM
Labor Day Sinking Feeling itsaboat General Discussion (sailing related) 2 09-06-2012 01:58 AM
That sinking feeling GaryHLucas General Discussion (sailing related) 17 08-26-2012 08:55 PM
That sinking feeling. PSS. SimonV Gear & Maintenance 18 04-08-2008 07:54 AM
Sailing: Movistar get that sinking feeling (Guardian Unlimited) NewsReader News Feeds 0 05-21-2006 11:15 PM
