Refurbishing CCA boats - Page 17 - SailNet Community
 163Likes
post #161 of 296 Old 10-12-2015
Freedom Chip Counter
scubadoo's Avatar
Re: Refurbishing CCA boats
I’ve been working on re-finishing / furbishing a 1969 Pearson Wanderer. It’s been a great experience for someone with very little keel boat time. Before I had acquired the vessel I spent a lot of time perusing this forum and came away with the impression that I really should know the boat inside and out before dropping it in the water.
In retrospect I think I should have taken the previous owner’s advice to just put the thing in the water and start sailing! That way I could have discovered where the real need for upgrades and repairs were. Just sitting there in the yard it’s difficult to determine the weak links….sure there are obvious items, but until you stress the rigging, motor, rudder, life lines, you’re really just speculating. Of course many of us on the forum seem to be professional speculators! It’s a sport we enjoy! Don’t get me wrong, there is a ton of invaluable information here also….just have to be diligent.
Re-finishing an aging vessel is a great educational experience….that may be where the true investment pays dividends. In 2 years, after bumping off docks, running aground, coping with cross currents, I hope to sell her and move into something made in this century! But in my mind, I have not “earned” that privilege just yet.
Best,
doo
SloopJonB likes this.
Tartan 31
scubadoo is offline
post #162 of 296 Old 10-12-2015 Thread Starter
Less Senior Senior Member
Originally Posted by scubadoo View Post
I?ve been working on re-finishing / furbishing a 1969 Pearson Wanderer. It?s been a great experience for someone with very little keel boat time. Before I had acquired the vessel I spent a lot of time perusing this forum and came away with the impression that I really should know the boat inside and out before dropping it in the water.
In retrospect I think I should have taken the previous owner?s advice to just put the thing in the water and start sailing! That way I could have discovered where the real need for upgrades and repairs were. Just sitting there in the yard it?s difficult to determine the weak links?.sure there are obvious items, but until you stress the rigging, motor, rudder, life lines, you?re really just speculating. Of course many of us on the forum seem to be professional speculators! It?s a sport we enjoy! Don?t get me wrong, there is a ton of invaluable information here also?.just have to be diligent.
Re-finishing an aging vessel is a great educational experience?.that may be where the true investment pays dividends. In 2 years, after bumping off docks, running aground, coping with cross currents, I hope to sell her and move into something made in this century! But in my mind, I have not ?earned? that privilege just yet.
Best,
doo
What all have you done and what surprises have you found?
seaner97 is offline
post #163 of 296 Old 10-12-2015
Senior Moment Member
SloopJonB's Avatar
If you are planning to buy something built in the new Millennium you better be very picky and have a fat wallet.
scubadoo likes this.
SloopJonB is online now
post #164 of 296 Old 10-12-2015
There are good old boats with good bones that are built to a level of quality that allows them to be a potential refurbishment candidates. There are tired old boats that were originally cheaply made that have not been maintained and are better consigned to the dumpster. If you are not very sure of what you are looking at you better hire a good surveyor and LISTEN to what they say. An unfinished refurbishment will result in a complete loss of your investment. Pick the correct boat to refurbish, make sure you understand the TOTAL cost of said refurbishment and make sure you have the funds to complete the refurbishment.
Shock out.............
Shockwave is offline
post #165 of 296 Old 10-12-2015 Thread Starter
I've had TWO that have gone over her and pronounced her in "above average to excellent" condition from a mechanical and sailing standpoint, and have commented on how stoutly "these old boats were built" and how they are "far better than the crap built today". (Direct quotes as I recall them). That would fly in the face of the discussion we have been having, so, while a surveyor may be helpful, it probably isn't the end all.
But there is certainly wisdom in what you've added.
Ocean- that which covers 3/4 of a world made for man, who has no gills.
seaner97 is offline
post #166 of 296 Old 10-15-2015
scubadoo's Avatar
The bad:
After removing 46 years of bottom paint…literally about an 1/8” thick…I discovered 2 large areas of bondo, approximately 18” in diameter. No visible damage from the inside, not too sure what to make of it?
46 years of DYI wiring….there are maybe 12 legitimate working connections, out of 60 plus wires. No-one removed the old ones when there was a short, they just ran a new one!
Fiberglass “tubes” for the scuppers and sink drain that terminate below the water line!
Leach almost completely blown out and severely tattered on the mainsail.
The good:
3” hull reinforcement ribs (stringers) at 5’ on center originally installed by the factory.
No sag in the deck stepped mast support. It was designed with a steel plate spanning between 2 forward bulkheads.
Solid rudder.
It is a little cliché, by now, but the surveyor actually said (when looking at the hull thickness, full keel layup from the inside, engine mount and the stringers ) “they don’t built them like this anymore!” Good or bad, several people in the yard are also made similar comments.
Appears to be fairly “idiot proof”…..good thing!!
Tartan 31
scubadoo is offline
post #167 of 296 Old 10-15-2015
SloopJonB's Avatar
TFiberglass “tubes” for the scuppers and sink drain that terminate below the water line!
As long as they are very solid (like as solid as the hull) having the scupper drains done like that is no bad thing - they provide reinforcement for the cockpit and eliminate through hulls, hoses & hose clamps, all of which can fail. It's fairly common in metal boats.
The sink drain not so much - too much potential for flex.
post #168 of 296 Old 10-15-2015
scubadoo's Avatar
Great to know!! (I was a bit worried there)
The sink has a black rubber hose connecting to the fiberglass tube above the water line...hopefully will ease the stress on the tube?
Crazy thing is someone (I don't think it is stock) connected one of the bildge pumps to that little extension of rubber hose....I'm thinking when the bildge pump turns on the contents are going to take the path of least resistance and come flying up through the sink drain. If I'm moving, I suppose there may be a siphon effect, but if I'm at the dock, I'm picturing bildge water dripping from my cabin ceiling!
Tartan 31
scubadoo is offline
post #169 of 296 Old 10-16-2015
al brazzi
Talking about boats in any context as investments is absurd - they are lifestyle expenditures. Does anyone ever speak about "investing" in ski lift tickets or trips to foreign countries? At least with boats you do have a hard asset with some value, not just memories.
True Dat! I rationalize it as two separate things. The "parked money" used to own the Boat and "upkeep" money, maintainence, upgrades, dockage, out and about money. I had a friend who owned a Ferrari for a while until the $800 spark plug wires got to be too much then he got his "parked" money back from the sale.
Even this has to be right one to appreciate but just recouping the purchase price however tough can be maintained by the upkeep money.
But then I don't have a restoration Boat (or the Ferrari for that matter), that would skew the whole thing.
albrazzi is offline
post #170 of 296 Old 10-24-2015 Thread Starter
As the winter season approaches, my list for this offseason includes standing rigging/chainplates, a couple electrical gremlins, replacing the old compression post step with a block of g10 and new lifelines. I'm half done with a new salon table and have a bunch of black locust (New England teak) to make a cockpit grate. Anything the experts would recommend I do/look at at the same time?
seaner97 is offline
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Pendragon35
Older CCA boats with rounded robust overbuilt booms...added boom vang needed? souljour2000 General Discussion (sailing related) 23 06-11-2016 08:43 PM
CCA - Cold Cranking Amps question The Sailing Podcast Diesel 13 09-23-2012 11:41 PM
CCA / MCA requirement for a Perkins 4/154M? TQA Electrical Systems 2 04-08-2011 08:15 PM
IOR...CCA... help! sherbet Boat Review and Purchase Forum 7 05-22-2006 10:38 PM
Morgan 33 (CCA) ricekrgr General Discussion (sailing related) 0 12-19-2002 10:41 AM
