Refurbishing CCA boats - Page 18 - SailNet Community
 163Likes
post #171 of 296 Old 10-30-2015 Thread Starter
Less Senior Senior Member
Re: Refurbishing CCA boats
Jeff- been awhile.
I've contacted a couple guys I know that insure boats. They have never heard of that study and couldn't find it. Their personal experience contradicted it. Any other leads on it?
Ocean- that which covers 3/4 of a world made for man, who has no gills.
seaner97 is offline
post #172 of 296 Old 10-30-2015
grumpy old man
I read the thread. You guys seem to have this covered pretty well.
I'll say this. In the early 60's no one knew much about "engineering" laminate schedules so they compensated by building thick. I think the original Rhodes Reliant has shrouds attacked to u bolts in the deck. Chainplates are over rated! Thick works. I am not advoctating bolting your shrouds to the deck!
Thick really works if you are rebuilding an old boat. Your shell should last maybe forever? We just don't know. Cored decks can be a problem. But solid lam hulls are going to be around a long time.
That's it for me. If I had to chose one boat that has been mentioned here I;d have to say I have always had a soft spot for the C&C 35 MK 1. What a sweeeeeeeet boat.
Bob's Blog ....
bobperry is offline
The Following User Says Thank You to bobperry For This Useful Post:
seaner97 (10-30-2015)
post #173 of 296 Old 10-30-2015 Thread Starter
Thanks Bob. Really nothing to add regarding areas that could have been done better in the 50s-70s era that would have made the boats more bomber? Maybe PCP is REALLY full of it if there isn't much we could do to reinforce them or make them better as owners.
And yeah, the C&C 35 always looked like a sweet boat.
seaner97 is offline
post #174 of 296 Old 10-31-2015
it's a long story
turboduck's Avatar
I disagree with the consternation. Work hardening and stress cycles are a result of flex. If the boat is rigid enough it won't flex enough to matter. Glass flexes by breaking down microscopically - you can hear it if you severely flex a piece of glass - it makes a crunching sound.
If it doesn't reach that point in service, it's life is quite simply unknown - certainly longer than ours. The early glass cruising boats are 60 Y.O. now and going strong unless they haven't been maintained - look at Jerry Litton's Islander in Thailand - 50 in a year or so and it looks nicer than most new stuff.
Don't worry about some intrinsic lifespan of the material - no-one knows if there is one or if so, how long it is. Decide how much restoration work you are willing to do and find a boat that needs that much work.
So I'd like to add my two cents worth since I am a proud owner of a rock solid 1962 Columbia 29, but in reading through the thread I hit on the name Jerry Litton. Hey, who is he? Perhaps a long lost relative of mine? (I'm Donald Litton) Maybe good old boats are in our bloodline... There is only one weakness in mine, the mast base support and I'll be working on that soon. But she is still sailing strong (6-7 knots at the usual at 20-25 degrees of heel typically).
BTW I may have missed it but if you go to bluewaterboats.org and look at the Pearson Rhodes 41 you will see links to huge album of a total refit of one that is absolutely beautiful. Those old hulls are WORTH refitting. That 41 is on my short list of dream boats...
Here is album 3 they posted there:
https://www.facebook.com/media/set/?...1&l=c007ac6e98
Don
1962 Columbia 29 hull #37
turboduck is offline
post #175 of 296 Old 10-31-2015
Senior Moment Member
SloopJonB's Avatar
Jerry is on here as jerrylitton
SloopJonB is online now
The Following User Says Thank You to SloopJonB For This Useful Post:
turboduck (10-31-2015)
post #176 of 296 Old 10-31-2015 Thread Starter
And he's got a kicka** Islander that was refurbed professionally in Thailand. Pics on several threads to make you jealous.
seaner97 is offline
post #177 of 296 Old 10-31-2015
grumpy old man
Yeah, I've seen Jerry's boat. It's a keeper. It's an Islander pretending it's a Hinkley.
seaner97 and aeventyr60 like this.
Bob's Blog ....
bobperry is offline
post #178 of 296 Old 11-02-2015
mstern's Avatar
Any one interested in refurbishing plastic classics should check out Tim Lackey's website lackeysailingdotcom. Tim fixes up some beautiful CCA inspired boats and makes them better than new. He also documented a spec project: the complete rehab of a derelict Pearson Triton into a modern "classic" daysailer.
mstern is online now
post #179 of 296 Old 11-02-2015
Hey I've got a Rhodes Reliant. Early build, too. It actually has regular chainplates, attached to knees on the hull. Its original.
I have seen exactly what you mention on some other boat, though.
chris95040 is offline
post #180 of 296 Old 11-02-2015
grumpy old man
Chris: I think there were some variations on the Rhodes Reliant theme. It could have been an original Bounty that I saw.
Bob's Blog ....
bobperry is offline
Older CCA boats with rounded robust overbuilt booms...added boom vang needed? souljour2000 General Discussion (sailing related) 23 06-11-2016 07:43 PM
CCA - Cold Cranking Amps question The Sailing Podcast Diesel 13 09-23-2012 10:41 PM
CCA / MCA requirement for a Perkins 4/154M? TQA Electrical Systems 2 04-08-2011 07:15 PM
IOR...CCA... help! sherbet Boat Review and Purchase Forum 7 05-22-2006 09:38 PM
Morgan 33 (CCA) ricekrgr General Discussion (sailing related) 0 12-19-2002 09:41 AM
