Refurbishing CCA boats - Page 28 - SailNet Community
 163Likes
post #271 of 296 Old 07-06-2016
SFBay Sailor
nhsail's Avatar
Dock
Re: Refurbishing CCA boats
here are 63 Hinkley Burmuda 40s out there for 145K. They still have 50 year old systems that either have or need to be replaced. Jeff had a second hand experience with one that the tabbing had come loose when it was NEW, so it can't be that that was all that much better. The decks don't have as many issues is the only thing that I think has been reliably documented as being better than a Tartan/Pearson/Bristol/Albin/etc (although that may just be that there are fewer of them, and who is going to admit that their Hinkley had to have it's deck recored?). Does that make it 4-5x the boat? Does it even make it 'superior'? Or does it just make it a boat that resales higher (and is more expensive when YOU buy it as well)?
Well my B-40 is a 1962 and we paid a bit less back in 2000, so maybe this will not be applicable:
I can tell you that my deck is not cored, it has half round tubes glassed in for reinforcement in the foredeck and side walks, and the cabin top is pretty solid layup. You can bounce on the foredeck you thud on the cabin.
All fittings are tapped into the glass, and then backed with washers & nuts .
The deck/hull joint is legendary, 6" flange on hull, and all the bulkheads and joinery are in place before the deck is fitted, epoxy and through bolts, with chain plates extending through to bulkheads. The centerboard has been bent once, and the lifting tackle replaced once when the 50 yr old bronze strap corroded through.
When we installed the interphase scanning sonar they had to counter bore from inside as the layup was thicker than the 4" sonar threaded stem.
The systems were state of art in '62 and have now been obsoleted/replaced multiple times. The custom tapered mast has massive sheaves and external halyards, it gets laughed at by the racers, then again their sticks don't have 50 yrs of service and we had carbon booms from Spruce trees back then, and replaced the main with Alum in 2002. Mizzen still spruce.
The interior joinery is partially converted to Herreshoff finish where the nicks and scars made the varnish too beat up, but the teak and holly sole is going strong.
Tanks for freshwater, shower sump, and reserve fresh water are stainless. Fitted a holding tank this year and gave up the lockers under port V-berth. (all 6 berths have lee boards, there are 4 hanging lockers and the freezer/refrigerator were air and water cooled, not to mention the diesel heater being forced air, the stereo was am/fm/cassette)
She's been repowered 2x, most recently in 1991, and at a few hundred hours a year the westerbeke W46 is going for a long time. Next go-round will possibly be electric with a small genset and LiPolymer batteries, but waiting for that to settle down.
The fuel tank is Monel, and placed under the engine.
We just did a re-spin of the electronics after 15 yrs and have replaced the old filament 12V lights with LEDs.
She was peeled and barrier coated from waterline down in 2000 and has been awlgripped multiple times on topsides and deck.
remaining significant work: Peel/grind deck and cabin to glass, fair and paint.
Re-wire, removing 50 yrs of accumulated dead ends and upgrade power panel to reflect modern use.
Replace 6V golf cart batteries with LiPolymer
Re-power with Electric drive and prop set for generation.
seaner97 and seabeau like this.
nhsail is offline
post #272 of 296 Old 08-29-2016
Has anybody done any work on a 1961 Palmer Johnson Challenger 38' Yawl named Whisper out of Quissett Harbor? My husband's family had it built in 1961 and he grew up sailing on it. Its original name was Kuwi. For fun we are trying to track it down.
mrock is offline
post #273 of 296 Old 09-14-2016
TomMaine's Avatar
The last owner was Rick O'Connell and sadly, here's his obituary. He has many posts on the owners website for the Alden boats like the Challengers. He loved WHISPER. I'd be interested in any info may give me about your husbands family having it built. Thanks!
949 - a forum for Alden yachts ? View topic - Rick O'Connell's obit
Tom Young sailing a 1961 38' Alden Challenger, CHRISTMAS out of
Rockport, Maine.
'I'd have written a shorter post, but I didn't have the time', Mark Twain.
TomMaine is offline
post #274 of 296 Old 10-29-2016 Thread Starter
Less Senior Senior Member
Very cool. Wish I could find some info on POs on my Pearson.
Off season list for this year is shorter- install saloon table, new dodger and main cover, soda blast and barrier coat for her bottom and a new steering cable. Maybe some new cushions if the budget holds.
Ocean- that which covers 3/4 of a world made for man, who has no gills.
seaner97 is offline
post #275 of 296 Old 10-29-2016
May God Bless You
longjonsilver's Avatar
auction of boats in Toronto. A Hughes 38 (with incorrect specs heh heh) named SV Sturm Vogel to be auctioned off. Probably will go for the minimum $25. Who can rescue it?
jon
longjonsilver is offline
post #276 of 296 Old 10-29-2016
roverhi's Avatar
jon
I can't rescue it but someone might if you posted where to find out about the boat
roverhi is online now
post #277 of 296 Old 10-30-2016
May God Bless You
https://www.bidspotter.com/en-us/auc...id-danbur10019
Lot # 37
teak decks, mast up, a4 engine, dark green, frame for winter cover, interior in reasonable shape
jon
edit: 475 Unwin Avenue
Toronto
ON
M4M 3M2
Canada
post #278 of 296 Old 11-03-2016
TomMaine's Avatar
My off season list is shorter this year, too. The cockpit I built the winter before has been given a good test for a season. I'm very pleased with the results. It's going gray.
One project I'll do this off season is move the mainsheet. I've researched the move, inspected a ton of old boats - mostly CCA era - and even did a few mock-ups to try different arrangement. I've settled that there is no perfect mainsheet arrangement.
The one I have now (as designed 61') works. But I'm tired of several problems with it. A lot has to do with how one sails.
This is basically what I'll do. But my boat budget won't allow a control line traveler or a self tailing winch(maybe later). I'll re-use the cabin top 2 speed winch - keep the old traveler - and cleat the mainsheet.
Rockport, Maine.
TomMaine is offline
post #279 of 296 Old 11-03-2016 Thread Starter
Whole bunch of Barlow winches on eBay that Hutton will convert to self tailing and fully refurb for 1/4 price of new.
seaner97 is offline
post #280 of 296 Old 01-06-2017 Thread Starter
Well- Soda Blast and barrier coat turned into a bigger grind and fair job than anticipated as some PO yahoo had just rolled resin on instead of the barrier coat that we thought was there. But at least it's getting done right. Some of the other 'upgrades' are going to get put off as this ate into the budget for them.
seaner97 is offline
Older CCA boats with rounded robust overbuilt booms...added boom vang needed? souljour2000 General Discussion (sailing related) 23 06-11-2016 07:43 PM
CCA - Cold Cranking Amps question The Sailing Podcast Diesel 13 09-23-2012 10:41 PM
CCA / MCA requirement for a Perkins 4/154M? TQA Electrical Systems 2 04-08-2011 07:15 PM
IOR...CCA... help! sherbet Boat Review and Purchase Forum 7 05-22-2006 09:38 PM
Morgan 33 (CCA) ricekrgr General Discussion (sailing related) 0 12-19-2002 09:41 AM
