What kind of hardware for a Bow pulpit? - Page 2 - SailNet Community
 1Likes
post #11 of 19 Old 08-27-2015 Thread Starter
Re: What kind of hardware for a Bow pulpit?
Originally Posted by overbored View Post
since the deck was not designed to have pulpit I would use the g10 to make the deck stronger.
Just the person I would hope chime in. I am going to be up in OC today for work and of course Minnies. Can I get some G10 locally? How about a source for Acrylic in OC?
I will be in SD county tomorrow if anyone knows of a source in SD?
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
Last edited by jephotog; 08-27-2015 at 08:55 AM. Reason: Changed Plexiglass to Acrylic.
jephotog is offline
post #12 of 19 Old 08-27-2015 Thread Starter
Here is what it looks like down below on the two aft posts of the pulpit.
How large of a piece of G10 should I laminate onto the roof?
Should I use thickened or just normal epoxy?
While I am at it getting supplies. How about a source for stainless steel also? My bow eye may need a large piece to cover the butyl tape seal.
I am pretty good when it comes to gluing with epoxy, but am too embarrassed to show the build ups up top I made to create a platform to mount the pulpit onto.
Jordan
Oceanside CA
jephotog is offline
post #13 of 19 Old 08-27-2015
I like thickened epoxy, because it doesn't drip. Piece of g10 could be 3x5" maybe?
What I do is : bond the g10 underneath, then drill holes, also countersink above deck, then fill holes with un thickened epoxy to seal the core, then drill again with smaller holes.
MarkSF is offline
post #14 of 19 Old 08-27-2015
overbored's Avatar
best source for g 10 is Mc master carr or call OC plastics
"GOLD RUSH" PRINDLE 16
overbored is online now
post #15 of 19 Old 08-27-2015
GeorgeB's Avatar
Garolite is a high strength, high density material that is used widely in the electronics industry in multi-level circuit card assemblies. The “-10” refers to the high strength variety (there are other numbers that represent heat, chemical resistance, etc). I have a diamond blade for my saber saw so I can easily cut different shapes. You can work it with carbide blades and drills. You will want to use thickened epoxy if you are mating to an ill regular surface. The backing plate only needs to be a little larger than its mate on the opposite side in most cases (and I think yours). I use lanocote on my screws for ease of removal when I set the epoxy and then ream out the holes with a drill after everything sets. Don’t forget to line your drill hole with epoxy as I think you are going through a bit of plywood core on the deck.
George B
2000 Catalina 34 MkII
Alameda, Ca.
GeorgeB is online now
post #16 of 19 Old 08-27-2015
Jamestown Distributors sells G10 cut into various sizes that are handy for backing plates. Of course, you pay a price premium over the raw material, but don't you always?
MarkSF is offline
post #17 of 19 Old 08-27-2015
or maybe not... a 6" x 6" x 1/4" piece is $19.26 at McMaster Carr. A 6 pack of 3" x 6" x 1/4" backing plates is $24-75 at Jamestown Distributors. So, much less expensive, AND cut to size.
MarkSF is offline
post #18 of 19 Old 08-27-2015
overbored's Avatar
that is a good price but the OP is about 30 minutes from mcmaster and if time is money? james town is 3000 miles and plus shipping and 1 week away and it is sailing season. better then g 10 is this chemical resistant 1/4" sheet it is not quite as strong but is white and a lot cheeper and i have been using it fir years with very good results.
12" x 24" sheet 1/4" $28.89 Each
mcmaster number 2194K23
they have larger sheets also
Chemical-Resistant Sheets—Smooth Finish
Color: Opaque white
Max. Temperature: 265° F
Width and length tolerances are ±1/8". Thickness tolerance is ±0.015". Flatness tolerance is not rated.
12" × 24"
24" × 24"
24" × 36"
Thick. Each Each Each
1/4" 2194K23 $28.89 2194K27 $46.87 2194K29 $64.21
post #19 of 19 Old 08-30-2015 Thread Starter
I ended up finding some G10 scraps at a plastic store locally. I got a few pieces for $10. Also got some Stainless Steel from the scrap pile at metal supplier.
I ended up cutting some backing plates custom. The last time I tried it i used way too thick steel and just got frustrated. This steel was still hard to work but not too bad. Photos to follow when finished.
Now what should I bed this with? I was going to line the bottom of the pulpit and the tapered holes with butyl tape but I also have some Life Caulk and some 4200. So far I have used butyl tape for all my mounting but the nature of this might have some flexing and need something more.
Also I am going to mount a bow eye for hoisting onto the trailer. What should I use to bed that?
Jordan
Oceanside CA
jephotog is offline
Can I get rid of the Bow pulpit? luckyboy1228 General Discussion (sailing related) 19 09-28-2014 11:14 PM
Damaged Bow Pulpit talessi Newport 4 03-19-2013 08:54 PM
bent bow pulpit deniseO30 Gear & Maintenance 13 11-05-2007 06:57 PM
Bases for bow pulpit LuckyinLA Gear & Maintenance 4 09-28-2003 09:12 AM
