Turbo wastegate sticks - SailNet Community
post #1 of 3 Old 09-07-2015 Thread Starter
It's identified as standard routine maintenance to disconnect the linkage on our Volvo TAMD31S and exercise the gate. Indeed, I find it stuck often. It has gotten to the point where I do so every single time I head out. I was even putting a bit of penetrating oil on the pivot, hoping it would stay free. No luck. In fact, I'm worried there could be seals that don't like it. More often than not, I have to smack it to free it up. No way the vacuum actuator would open the gate on its own.
Any ideas on a lubricant that might stay under all that heat. Doubt it.
Jeanneau 54DS
Minnewaska is offline
post #2 of 3 Old 09-07-2015
Re: Turbo wastegate sticks
No oil or solvent. High temperature bearings are either metal on metal or cooled and flooded with high presure oil. Oil on metal to metal burns at high temperatures leaving carbon deposits.
Be prepared to repair or replace before it fails.
Zen is a matter of recognizing reality.
desert rat is offline
post #3 of 3 Old 09-07-2015 Thread Starter
Good point. Something odd about the design that it needs to be exercised. I may strip it down this winter.
Jeanneau 54DS
Turbo temps Minnewaska Gear & Maintenance 1 10-01-2012 01:29 PM
Turbo Diesels tdw Gear & Maintenance 26 02-26-2010 10:30 PM
Pulled the sticks and didn't break anything CharlieCobra Gear & Maintenance 7 08-15-2009 09:46 PM
Anchor chain sticks in windlass dhornsey Gear & Maintenance 8 08-05-2008 09:43 PM
What sticks to teak? jr438234606 Gear & Maintenance 2 10-26-2006 11:11 PM
