Solar powered light for mast head? - SailNet Community
 15Likes
post #1 of 25 Old 09-11-2015 Thread Starter
krisscross's Avatar
Are there any solar powered lights that can be mounted on top of the mast? Eliminating wires going to battery through the mast. These days there are so many self contained lights out there. If they were marine grade, that would make them worth installing.
Plato
krisscross is online now
post #2 of 25 Old 09-11-2015
Moderator
MarkofSeaLife's Avatar
Dock
No wires. How do you turn it off when sailing at night?
Maybe a remote control?
I found the USA to be totally backward when it comes to solar so you might have to look for stuff on the internet in Singapore or Australia.
krisscross likes this.
MarkofSeaLife is offline
post #3 of 25 Old 09-11-2015 Thread Starter
krisscross's Avatar
Re: Solar powered light for mast head?
I was thinking of keeping it on all the time, as in that rule:
25(b) In a sailing vessel of less than 20 meters in length the lights prescribed in Rule 25(a) may be combined in one lantern carried at or near the top of the mast where it can best be seen.
Plato
post #4 of 25 Old 09-11-2015 Thread Starter
krisscross's Avatar
This is one example of a unit that could be modified for masthead use:
Elegant solar-powered Shine light delivers 30+ hours of portable LED illumination with just one charge
Plato
post #5 of 25 Old 09-11-2015
S/V Caper Nonsuch 36
flyrod's Avatar
OGM, owned now by Aqua Signal is working on one. Not sure of current status, but
they were working on prototypes last I knew about 6 months ago. Check with them.
flyrod is online now
post #6 of 25 Old 09-11-2015
travlin-easy's Avatar
There are lots of solar powered lights that would do the job. Most are set up for lawns and walkways, but they would be more than adequate. You could just strap it to the top of the mast with some wire ties, the light turns off automatically at sunup and turns on at dusk. Less than $10 at several big box store locations. I have some 16-foot rope lights along the toe rail on each side of the boat, stays lit about 12 hours before running out of battery. During the day, the batteries charge completely. No one can mistake me when entering a dark anchorage.
All the best,
Gary
krisscross and carlwk3c like this.
travlin-easy is offline
post #7 of 25 Old 09-11-2015 Thread Starter
krisscross's Avatar
Well Gary, I do not want my boat to look like a Christmas tree I wanted a light that actually meets the navigation requirements.
Plato
post #8 of 25 Old 09-11-2015
Moderator
Dock
Yep, I like the one you linked to.
For 39hours it must have a better battery. The garden type ones have very low miliamp hour batteries. I change them for larger.
Also you could remove the stand at bulb and put in a uscg rated led bulb.
Invent it yourself
post #9 of 25 Old 09-11-2015
At anchor you need one all-round white light. Underway you can have a combined tricolour. You need switches to turn one off, and the other on, unless you plan to sail around the world and never stop.
MarkSF is offline
post #10 of 25 Old 09-11-2015
Master Mariner
capta's Avatar
Before I purchased our solar panels I bought 6 garden path solar lites to learn about the realities of solar. Yes they would charge on a cloudy winter day in New England. Yes they seemed to always work OK, even when buried under a few inches of snow. But every 8 months to a year, you've got to put in a new set of rechargeable batteries.
So, to answer your question, how would you feel about going aloft maybe 3 times over a couple of years to change the batteries? I think I'd rather just run the wires once and change a completely maintenance free light every 10k hours or so. By the way, ours is probably around 16k hours now and still going strong.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
Solar powered cooling Frogwatch Gear & Maintenance 15 02-22-2014 08:19 AM
This super-yacht is solar powered NewsReader News Feeds 0 01-25-2013 11:20 AM
Mast Head Light Freesail99 Gear & Maintenance 21 03-27-2011 09:40 PM
solar powered vent Walt352 Gear & Maintenance 15 11-20-2010 06:38 PM
mast head light caliber LRC 2000 hasuehounds Caliber 1 03-08-2009 10:03 PM
