Anyone dive to clean their own bottom? - Page 9 - SailNet Community
 35Likes
post #81 of 86 Old 10-05-2015
AdamLein's Avatar
Re: Anyone dive to clean their own bottom?
Just cleaned Laelia's hull for the first time, freediving only. What a blast! I haven't been in a wetsuit in ten years or so, the smell of salt+neoprene+shampoo brought back lots of good memories from BC. With six pounds of ballast I was still a bit buoyant, but I did it in our slip and was able do most of the shallow work by going supine with my feet on the side of the dock. Scrape scrape scrape with a bamboo spatula, then push off to get the deeper bits, the surface and repeat. To hang out near the keel I could just hold on (again upside-down, so I'm essentially pulling myself down). In other areas I found I could sort of go on all foursThe hull was mostly free of hard growth with the exception of the bottom of the keel, the paddlewheel, and the raw water intake (eek). There was a thin layer of slime and lots of .... I dunno, something that looked like shrubbery but was very loose and easy to remove (even swishing with water would take it off). The process took about an hour with plenty of surface time to exchange bad air for good. Can't wait to go again... probably a month from now.
However the prop and shaft were pretty heavily fouled -- I'll have to bring a steel scraper next time -- and the zinc is noticeably eroded. I'd like to replace it on my next dive but I'm concerned about getting a good electrical connection with the shaft. Can I wire brush the shaft where I plan to install the zinc? I'd also appreciate any hints or tricks on zinc replacement when freediving.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #82 of 86 Old 10-05-2015
Some zincs have captive screws, some don't. Captive screws make the job a bit easier.
If the zinc is noticeable eroded after a month or two then you have good electrical contact. I expect mine to be half gone, replaceable, in 6 months time. Yes, you can wire brush the prop and shaft. I use fine waterproof sandpaper.
Dive often and the job is much easier. Twice as often might take a quarter the time.
"...there are two kinds of opinions, those based upon tradition ... and those having something in their favor." B. Russell
aloof is offline
post #83 of 86 Old 10-05-2015
I don't discuss my member
Fstbttms's Avatar
Yes but 80 grit sandpaper is better.
Use an air supply.
Fstbttms is online now
post #84 of 86 Old 06-11-2016
What pad are you using on that trowel? I started using 'astro turf' remnants and they work pretty good. Is that floor buffer pad? or?
mainsailman is offline
post #85 of 86 Old 06-12-2016
Fstbttms's Avatar
It's a 3M Doodlebug pad mounted on a custom holder:
post #86 of 86 Old 06-12-2016
stray currents are an issue for fresh water not so much for salt. I can get most of my bottom with a pressure washer, extension, and a gutter tool at the end
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Waltthesalt is online now
Clean bottom how much? lapworth Gear & Maintenance 51 01-19-2013 10:49 PM
How do you clean your bottom? paul323 SailNet FAQ 24 12-23-2011 09:35 PM
How to Clean a dirty bottom jephotog Gear & Maintenance 14 09-08-2009 11:55 AM
How do you clean the bottom? razorseal Gear & Maintenance 5 02-23-2006 12:06 PM
Diver to clean bottom..how much $ Wega24 Racing 5 08-19-2002 08:03 AM
