Dripless shaft seal - Page 3 - SailNet Community
 10Likes
post #21 of 31 Old 10-28-2015
bell ringer
Don L's Avatar
Re: Dripless shaft seal
I've had this happen. Really the only thing that fail that going to really be be a lot of water is the rubber boot/bellows. I wrapped it with rescue tape and it lasted 3 months with no leaks till I could haul out.
But that is why I replaced with a Next Gen II seal afterward.
MedSailor likes this.
Don't blow air up my rear, be useful and blow it at the sails!
Don L is online now
post #22 of 31 Old 10-29-2015
SeaDubya's Avatar
Originally Posted by paul323 View Post
All PSS seals should have a collar fitted on the shaft to make sure the ring does not move. Two small grub screws (which cannot be retightened) is IMHO a major failure risk.
I use a spare shaft zinc to help keep mine from slipping.
RobGallagher and outbound like this.
~Chris
All sailors are cruisers, but not all cruisers are sailors. A smooth sea never made a skilled sailor.
Also try:
(it's new!)
SeaDubya is offline
post #23 of 31 Old 10-29-2015
I've been using this from PSS.
-- PYI Inc. Max-Prop PSS Shaft Seal Seaview Radar Mounts R&D --
"shaft retainer"
capecodda is online now
post #24 of 31 Old 10-29-2015
HANUMAN
RobGallagher's Avatar
I have to go with the "rescue tape". My stuffing box hose tore in half and it got me home. The wind died and I was even able to motor into port. Granted, most have never seen a bigger ball of rescue tape, amazing what one can do with three rolls of rescue tape and a boat full of water
I used to have some toilet wax on board as well...I should probably revisit that.
I have a dripless seal on current boat. I had to move the ring further aft last spring as I was getting a fine spray under power, but no leak otherwise. I'm not sure if the retaining ring actually moved or the bellows lost some of their spring.
My opinion is that the bellow lost a bit of springiness. The bellows appears like new so I think it will be good for another couple of seasons.
One thing for sure, they are just as much maintenance as a conventional packing gland. Maybe more....
WINDHOVER
1999 CATALINA 36 MKII
NOANK, CT
RobGallagher is online now
post #25 of 31 Old 10-29-2015
Originally Posted by brokesailor View Post
A friend on a rally on the Intercoastal had this happen to him.
That's classic, hard to imagine a more fitting failure to have occur on a freakin' Rally Down the ICW...
Except, perhaps, for something like a jammed/stuck zipper on a cockpit enclosure...
What was the exact nature of the failure?
brokesailor likes this.
JonEisberg is offline
post #26 of 31 Old 10-29-2015 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
JE: not sure. All I know is there was a lot of water. They were able to get it under control. They are proceeding ahead of the rally towards Beaufort to haul out the boat for repairs. Maybe they are going back to a normal stuffing box? Didn't want to probe
brokesailor is offline
post #27 of 31 Old 10-29-2015
Master Mariner
capta's Avatar
Just when I was thinking how nice it would be to have a dripless shaft seal, you had to come up with the one good reason NOT to get one.
Thanks. lol
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #28 of 31 Old 10-29-2015
Learning the HARD way...
eherlihy's Avatar
"shaft retainer"
Back in the day, before PSS carried the "Shaft Retainer," the solution was to go to McMaster-Carr and purchase a two piece clamp on shaft collar;
Available in standard;
Extra Grip;
or Easy Adjust;
Some of the available materials include Aluminum, 303 Stainless, 304 Stainless, 316 Stainless, Nylon and Delrin
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
post #29 of 31 Old 10-29-2015
Me too, works great.
IStream is offline
post #30 of 31 Old 10-29-2015
Extra Grip;
or Easy Adjust;
I have a 1" shaft, let's say the distance between the shaft seal collar and my shaft coupling is 5 inches...
I simply split a 5" length of 1" PVC conduit in half, and fit it into that gap...
Does the job, no way that collar is going anywhere, hasn't scored or marred the shaft in any way - which might possibly tear or damage the O-rings if a new collar replaces the old - at a cost of perhaps 20 or 30 cents...
Dripless Shaft Seal versus Stuffing Box Cruisingdad Gear & Maintenance 73 05-07-2018 07:50 PM
Identify Dripless Seal Manufacturer? oysterman23 Gear & Maintenance 12 06-22-2015 07:20 PM
Dripless Packing seal is Dripping Valmika Gear & Maintenance 7 04-23-2011 09:55 PM
Shaft alignment with a dripless seal Downunder Gear & Maintenance 6 05-11-2010 03:30 PM
PYI dripless seal leaking drynoc Gear & Maintenance 18 01-19-2010 07:04 AM
