Adding a second bilge pump - Page 2 - SailNet Community
 3Likes
post #11 of 17 Old 11-14-2015
Re: Adding a second bilge pump
This is an informative site as well. An eye opener for some. As an ex offshore commercial fisherman, I always wanted a big jabsco to run off the engine, with a manual clutch. Pricey, but recommended for a real ocean voyager. Kevin
Boats, Yachts: All About Bilge Pumps - Those Essential Devices for Keeping Your Boat Off the Bottom
FloridaBoy is offline
post #12 of 17 Old 11-14-2015
Here's one with an electric clutch. Not sure if that's a good idea, in case you lose battery power. But must be some way around that. kevin
Electric Clutch- 62 GPM - Jabsco | Fisheries Supply
post #13 of 17 Old 11-14-2015
al brazzi
The way around that is a PTO drive. I don't know if any Marine engines offer this option but its direct and requires no electricity. That has always been my favorite Diesel feature once its running you need to run out of fuel for it to stop.
albrazzi is offline
post #14 of 17 Old 11-14-2015
This one has a manual clutch. I'm sure you could find a cheaper one, somewheres. Kev
JABSCO Flexible Impeller Clutch Pump | West Marine
post #15 of 17 Old 11-15-2015
al brazzi
Even a clutchless pump with the belt removed will work. Just put the belt on in case of emergency or to test.
albrazzi is offline
post #16 of 17 Old 11-15-2015
Converted car engines don't have pto's so all the pumps ,compressors and drum /gurdie drives were belt driven. Usually done on the fly, the engine idling. Bit of a nac to it and most everybody had at least one stubby finger .
Capt Len is online now
post #17 of 17 Old 11-15-2015
al brazzi
My uncle in CA is THE Jeep guy, they make Blenders from starter motors for the trail, and if someone needs a starter they just go without a blender for a while. They make welders from alternators too. So as with anything else if you're handy you can make this work.
RobGallagher likes this.
albrazzi is offline
Bilge pump cutoff delay? Narrow bilge Pamlicotraveler Gear & Maintenance 41 11-02-2014 12:44 PM
Adding automatic bilge pump to manual bilge pump FirstCandC Gear & Maintenance 13 04-03-2013 08:59 AM
cw manual bilge pump, bike pump type b40Ibis Gear & Maintenance 2 04-27-2011 07:26 PM
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 11:36 AM
Brand new bilge pump that doesn't pump.... ugh Lancer28 Gear & Maintenance 6 02-08-2008 08:26 PM
