what is my house bank capacity? - SailNet Community
 1Likes
  • 1 Post By Maine Sail
post #1 of 9 Old 11-09-2015 Thread Starter
bristol299bob's Avatar
One of my winter projects is to replace charger. I understand that I should size the charger based on ~10% of the capacity of the house bank. But thinking about it I realized that I don't really know the capacity of my house bank.
My 12v house bank consists of 4 Exide GC-110 golf cart batteries.
The specs for the GC-110 are:
- 220 Amps
- 6 volts
- Amp Hours (20 hr. rate): 186
- Minutes at 75 amps: 110
- RC Minutes: 390
so, for the purposes of sizing the charger, which value should use for the capacity of each batt?
Also I'm assuming that I'd multiply that capacity by two for the total capacity (a pair of batts in series, the two pairs in parallel)
1977 Bristol 29.9
Surprise
Hull #5
Oriental NC
bristol299bob is online now
post #2 of 9 Old 11-09-2015
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Re: what is my house bank capacity?
I think you're on the right track.
Two batteries in series will increase the volts and two batteries (or battery banks) in parallel increase the Ah's.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is online now
post #3 of 9 Old 11-09-2015
Each battery is therefore specified to be charged at 18.6 Amperes. Because, presumably, you have two 12 Volt banks to charge both banks in parallel would require a 37.2 Ampere charger. The reality is that you will only see these charge currents if the batteries are quite discharged, and then only for a short time. So buying a 40 Ampere charger may not be worth the expense and all. Ten or twenty would be fine by me.
"...there are two kinds of opinions, those based upon tradition ... and those having something in their favor." B. Russell
aloof is offline
post #4 of 9 Old 11-09-2015
Learning the HARD way...
eherlihy's Avatar
You have 440AH @ 12Vdc.
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
post #5 of 9 Old 11-10-2015
Super Moderator
Maine Sail's Avatar
- 220 Amps
- 6 volts
- RC Minutes: 390
Four Exide GC-110's in series>parallel is a 372Ah bank for the as new rating.. The Ah capacity is your 20 hour rate on the battery plate or spec sheet. 186 X 2 = 372.
CharlzO likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
The Following User Says Thank You to Maine Sail For This Useful Post:
eherlihy (11-10-2015)
post #6 of 9 Old 11-10-2015
Old enough to know better
Is there any disadvantage (other than excess cost) to going up a size on the charger?
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #7 of 9 Old 11-10-2015
amwbox's Avatar
- 220 Amps
Is it 220 [email protected] 20 hr rate, or 186 [email protected] 20 hour rate? What rate is the 220 measured from?
20 hour rate is usually considered standard, so 186 X 2 = 372 AH.
Divide by two because you shouldn't deplete below 50%, in order to avoid damaging the batteries.
When you batteries are tied together into a bank, think of them a single battery. During bulk charging, you want to be able to deliver 25% of charge amps to the battery. For example, if you have 200 AH of capacity, you want to be able to feed in 50 amps. Your dealing with flooded batteries, so you don't need the crazy high amperage of a AGM, for example. 25% is a good number for flooded batteries. They won't accept much more. If you want to charge faster, go with AGM.
"Freedom is the increased knowledge of what you can do without." —Thoreau
amwbox is offline
post #8 of 9 Old 11-11-2015
mitiempo's Avatar
No disadvantage. The batteries determine the acceptance, not the charger.
Brian
mitiempo is offline
The Following User Says Thank You to mitiempo For This Useful Post:
miatapaul (11-11-2015)
post #9 of 9 Old 11-11-2015
thanks, that is helpful. I figured as much, just did not want to make a huge mistake. I can get a deal on a larger charger, and figure I will eventually have a bigger bank, so might as well get it now rather than replace it later.
1976 C&C 33
House bank Dave_E Electrical Systems 8 01-19-2015 03:28 PM
House bank sizing katsailor Electrical Systems 10 08-27-2013 01:52 PM
House bank and things. deniseO30 Electrical Systems 29 03-28-2011 12:40 AM
6V House Battery Bank Capacity neilmcd Gear & Maintenance 11 02-22-2009 04:14 PM
House battery capacity wwilson Gear & Maintenance 7 03-07-2001 08:06 PM
