Winterizing your boat - SailNet Community
 1Likes
  • 1 Post By RobGallagher
post #1 of 7 Old 12-11-2015 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
When you winterize your boat in preparation for haulout do you leave your thru hulls open or closed? ( I normally leave them all closed then once I haul out I go back and open the thru hulls to get the water out of the ball valves. )
brokesailor is offline
post #2 of 7 Old 12-11-2015
Dock
Re: Winterizing your boat
I was just thinking about this the other day, that it might be better to leave them closed so as to prevent insects or whatever from climbing in from the outside, or building mud nests or anything of the sort. Luckily for mine, I have two - the sink which is constantly closed as there's no plumbing hooked to it. And the cockpit drains, which kinda have to stay open to ward off any snow or rain that might find a way in under the cover.
Horizons Found
1976 Newport 28
CharlzO is offline
post #3 of 7 Old 12-12-2015
redline's Avatar
I leave mine open in case any residual water or condensation should run down into the valve body. Those that are unused and normally closed (overboard discharge, capped internally) get opened them closed.
FWIW I've seen what happens when a water-filled ball valve freezes (fortunately, it was just an irrigation pump, not on a boat) - the little cylinder of water in the stainless ball pushed the valve body apart, splitting it.
Sent from my iPad using Tapatalk
Norman
s/y "Redline"
1998 Jeanneau SO45.2
redline is offline
post #4 of 7 Old 12-12-2015
Happens often when air temp in boat is much colder than the surrounding water. Thru hulls valves burst and boat fills when it warms up
Capt Len is online now
post #5 of 7 Old 12-12-2015
HANUMAN
RobGallagher's Avatar
In preparation for haul out, I leave them closed. I close my through hulls every time I leave the boat for more than a day.
After haul out I open them back up for the winter. After the last freeze I close them again, keeps the bugs from making nests and they are ready for launch!
Is it spring yet?
brokesailor likes this.
WINDHOVER
1999 CATALINA 36 MKII
NOANK, CT
RobGallagher is online now
post #6 of 7 Old 12-13-2015
Ditto. Close before haul out, then opened on the hard to drain and dry. Not worried about bugs, once the winter sets in.
Those in humid southern climates, however, need to close their thru-hulls for serious bug issues. However, freezing isn't an issue for them.
Jeanneau 54DS
Minnewaska is offline
post #7 of 7 Old 12-14-2015
Guyfromthenorth's Avatar
Living in Northern Canada I have done my share of winterizing as we regularly see -40 and -50 in my area. In my experience always leave the valves open, as mentioned before if a small amount of water freezes in the closed body (whether residual, or trickle down) it can split it pretty easily.
Bugs aren't much of an issue in my area, but mice, squirrels, etc are. On all opening I have (exhaust, air, vents, and plumbing) exposed to the outdoors I put a small wad of steel wool in them. It easily pulls out during the spring de-winterizing, and mice\bugs will not chew into it. Make a checklist if you have to of where you plugged so you don't forget in the spring and leave it in the galley.
Some youtube videos, nothing fancy
Guyfromthenorth is offline
Winterizing a boat sailingsteve General Discussion (sailing related) 11 01-20-2015 03:52 PM
What stays on the boat after winterizing. abrahamx General Discussion (sailing related) 21 10-31-2013 07:55 AM
winterizing timangiel Seamanship & Navigation 17 10-31-2006 04:55 PM
Is winterizing/antifreeze needed for in-water boat on Vancouver Island? FrankLanger Gear & Maintenance 5 09-20-2006 07:19 PM
Electical Grounding/Winterizing Boat on the Hard Cheetie Gear & Maintenance 2 11-12-2002 05:05 AM
