Thru-hulls, seacocks, and hoses! - SailNet Community
 2Likes
post #1 of 12 Old 12-16-2015 Thread Starter
Ok, I'm working on overhauling my Bristol 29.9. I'm replacing pretty much all of of the thru-hulls, seacocks, and all of the ancient plumbing. I want to run this by you all and gather some opinions.
For the seacocks, I'm basically planning to do what Compass Marine recommends at Replacing Thru-Hulls and Seacocks Photo Gallery by Compass Marine How To at pbase.com. Groco says to use 316 stainless bolts or lags. I'm not sure whether to bolt through the hull from the outside, lag into backing blocks from the inside, or purchase Groco backing blocks and bolt into the hex nuts. Thoughts?
And hoses...oh hoses. I've been agonizing over the options for hoses and think I have it figured out:
- For the 3/4" freshwater system (non-pressurized), I'm planning on using Trident Marine Reinforced PVC Water Hose, likely from Discount Marine Supplies.
- For the 1 1/2" sewage lines, Trident 101. ~22ft. Any leads on the best place to buy this?
- For the 3/4" holding tank vent line, Trident 148.
- For the 1 1/2" cockpit scuppers drains and sink drains, also Trident 101. ~10ft. I know these don't need to be odor safe, but I can figure out a better (ie cheaper) hose to use that's still adequate for critical below the waterline use.
- For the 1 1/2" potable fill lines and manual bilge pumpout, Trident 148 or 144. ~20ft.
- For the 1 1/8" automatic bilge, Trident 148 or 144.
Looks like it's easy to buy 50' lengths of Trident hose at a good price from Discount Marine. I'm wary of Shields after reading reviews, etc but it's definitely easier to go to WM and buy shorter lengths of the equivalent Shields hoses. Thoughts?
I'll take any thoughts, suggestions, or other ideas!
Thanks!
Phil
pmagistro is offline
post #2 of 12 Old 12-16-2015
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Re: Thru-hulls, seacocks, and hoses!
The Compass Marine site is a good one to go off of. A Sailnet member, Maine Sail is the one behind that site. Look through the older posts here and you can find a wealth of info from just him alone.
I have replaced one seacock so far and about to do 5 more. The way I did the bolts (bronze) was to counter sink within the backer board, epoxied into place, then epoxied to the hull. The one I did was for the raw water intake for engine cooling. Everything worked out just fine. Whether to go through the hull with the bolts would depend on location. My locations are at the curve of the hull toward the keel, but if you have a fairly flat area of the hull, then you could go either way, I think.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is online now
post #3 of 12 Old 12-16-2015
Bleemus's Avatar
Where did you see Groco saying to use Stainless bolts?
Sent from my iPad using Tapatalk
Keth
Boat Vinyl Lettering and Graphics
Bleemus is offline
post #4 of 12 Old 12-16-2015
Surely bronze fasteners would be ideal? They would be the same material as the seacock base, so there would be no galvanic corrosion.
Rhapsody-NS27 likes this.
MarkSF is offline
post #5 of 12 Old 12-16-2015 Thread Starter
I called and talked with them today, and the fellow said that 316 stainless or bronze are both fine materials. I think I'll go with bronze; they have all the possible bronze bolts/screws I could want at Fawcetts.
post #6 of 12 Old 12-16-2015
Bleemus's Avatar
You called Groco and they said that or did you just talk to a chandlery?
MaineSail where are you when we need you!
Keth
Bleemus is offline
post #7 of 12 Old 12-16-2015 Thread Starter
I called Groco directly.
post #8 of 12 Old 12-16-2015
casey1999's Avatar
What are the problems with Shields hose?
In the beginning, there was only water...
casey1999 is offline
post #9 of 12 Old 12-16-2015
Originally Posted by pmagistro View Post
...For the 1 1/2" sewage lines, Trident 101. ~22ft. Any leads on the best place to buy this?
- For the 3/4" holding tank vent line, Trident 148...
Phil
I re-plumbed the entire head including changing all hoses and a head rebuild last year. I bought all the hoses from Hopkins Carter Marine (Hopcar is a member here). His prices are very competitive and he can get most of what you need for this job including the Awab hose clamps that you'll need quite a few....
Not affiliated in any way, just a satisfied customer.
SVTatia is online now
post #10 of 12 Old 12-16-2015
fallard's Avatar
If you look at the photos in the OP's link to Maine Sail, you will see bronze bolts through the bronze flange.
fallard is online now
Through hulls and hoses Gregrosine General Discussion (sailing related) 6 04-24-2013 05:44 AM
thru-hulls without seacocks? robbieland Gear & Maintenance 8 01-27-2013 07:20 PM
Of thru-hulls and seacocks... utchuckd Gear & Maintenance 3 08-06-2012 04:48 PM
Replacing seacocks and through hulls. davewild Gear & Maintenance 8 03-04-2010 11:48 AM
New thru-hulls/seacocks ereuter Gear & Maintenance 27 05-07-2007 06:31 PM
