Harken MK I furler. Should I use it? Too old? Furlers vs hank on ? Your thoughts? - Page 4 - SailNet Community
 6Likes
post #31 of 33 Old 12-22-2015
Re: Harken MK I furler. Should I use it? Too old? Furlers vs hank on ? Your thoughts?
"I'm thinking of going the other way!
Is it possible to covert roller furling sails to hank on?"
Simple. A two-step process.
1) Call sailrite and discuss with them.
2) Then let us know what they say.
I am guessing a boltrope and some reinforcing tape (so the hanks don't tear out). Hanks are easy to fit; getting the boltrope to fit the sail correctly, with the correct halyard tension, will likely be fiddly. But if you have access to a good sewing machine, a lot os space (I commandeer the sailing club dining room) it is probably worth if for a cruiser/casual sailor - probably not a racer, as tolerances for racing sails are much tighter.
But having a good sewing machine is key. When I started trying to maintain my sails, I used a newer Singer. The needle penetrated, but the seams were not pulled fully tight. Within a year they frayed and failed. I ended up buying a Sailrite machine (but others have had luck with older, solid semi-industrial machines). The Sailrite machine was hellish expensive, but for me has paid its way in sail servicing and other repairs. I even made a jib from a Sailrite kit for about 50% of a loft sail - as much for the experience as for a cheap sail. Hard work. The layup in the corners was so thick the machine could not handle it (which is saying a lot), and I ended up using a hammer and nails, and hand sewing!
So if you enjoy projects like this, get the right machine, make mistakes, fix up your sails, have fun, and then go sailing.
skygazer likes this.
paul323 is offline
post #32 of 33 Old 12-22-2015 Thread Starter
skygazer's Avatar
Wow, hammer and nails!! That is more my type of sewing I guess. I don't know enough about sewing to know if I can enjoy it. But actually I do some work on boats that I don't really like, I just like having the job finished and working on boats in general.
I sewed a pants leg rip once with my wife's machine, but when it ran out of thread I was stumped! She has no interest in sewing but I think she can thread her machine. Stepping on the pedal and watching it zip along was kind of fun compared to hand sewing.
I admire that you have sewn your own sail. I don't race so casual is good enough for me. That is good to know about the threads have to be pulled tight. I just read in an older book that hand sewn sails were best because the threads did not stand proud and abrade. HA! If I did the hand sewing, which would require living almost forever, the uneven tension would rip the fabric.
skygazer is offline
post #33 of 33 Old 12-23-2015
Bleemus's Avatar
Originally Posted by skygazer View Post
Hi Bleemus. I wondered about this myself, and was hoping it would be as simple as attaching hanks to the tape by mechanical means or even sewing each one on.
How would you replace the tape with a bolt rope?
Not too good about sewing so yes, it is a serious question.
For a sailmaker it is easy as they have all the equipment on hand.
If you want to do it yourself you will need the following.
A length of boltrope tape purchased from a sailmaker.
Seam ripper
Hanks and Hank chafe guards
HEAVY DUTY sewing machine
Grommet punch and grommets.
Awls and vice grips with block and tackle attached to handle
STEPS
Remove old luff tape with seam ripper
Lay sail out on floor with a fold one foot behind luff and awl head and tack
Awl the head of the sail and top of new luff tape to the floor
Attach vice grips to bottom of luff tape and awl the block and tackle to the floor
Tighten block and tackle and tension the luff tape a lot more than you think
Staple the luff tape every few inches to the sail
Remove all the Awls
Stitch luff tape to sail
Punch holes for grommets and install grommets, chafe guards and then hanks.
Go sailing.
Probably forgot a step or two since it has been awhile. Very important that the luff tape goes on the sail with that block tension. You want the majority of load in the tape and boltrope not in the single layers of sail fabric. Only need enough tension in sail to adjust draft position. Nothing more.
Unless you have all this gear you are better off having it done professionally.
Sent from my iPad using Tapatalk
Keth
Boat Vinyl Lettering and Graphics
Bleemus is offline
The Following User Says Thank You to Bleemus For This Useful Post:
skygazer (12-23-2015)
Hank on to furler KejaGrad Gear & Maintenance 20 01-29-2015 04:55 PM
Harken Roller Furlers last mango Gear & Maintenance 7 09-26-2013 08:03 PM
Video: A hank-on headsail furler? MedSailor Gear & Maintenance 3 02-09-2012 02:21 AM
Guess who is finally ditching the furler and going hank up? chrisncate General Discussion (sailing related) 16 10-14-2010 09:34 PM
Question about Harken furlers FrankLanger Gear & Maintenance 7 01-17-2008 10:26 PM
