Automatic & Portable Bilge Pump - SailNet Community
post #1 of 15 Old 01-03-2016 Thread Starter
Does anyone know of or could recommend a brand/model bilge pump that is both automatic and portable? It also needs to be small enough to fit into the bilge of a Catalina 18. I would like to be able to just lay it down into the bilge, hook up the battery, and go. When I do sail, I would just disconnect it and take it out of the bilge. To simplify, I would not like the pump to be permanently fixed to the boat.
My reasoning behind needing one is that after a good rain, water somehow ends up getting in the boat. This is fine when I sail every weekend since I can remove the water with the manual pump, but I do not like the thought of water potentially sitting in the boat for extended periods.
As a disclaimer, the hull does not leak. The boat can sit in the water for weeks and be bone dry, assuming it does not rain.
Thanks for the help!
Rc26 is offline
post #2 of 15 Old 01-03-2016
Cruiser
wrwakefield's Avatar
Re: Automatic & Portable Bilge Pump
Rc,
I used the Whale Supersub pumps in a MacGregor 27 I previously owned years ago. [It had very shallow bilges...]
Whale Marine - Products
They have built-in electronic activation so you don't need to wire a separate switch. With the right hose and electrical connectors, it would be easy to make portable as you describe.
However, since it doesn't use power unless running, I would consider leaving it in to keep your bilge dry when it rains and in case of an emergency...
I hope this is useful for you.
Cheers!
Bill
SV Denali Rose
wrwakefield is offline
post #3 of 15 Old 01-03-2016
Master Mariner
capta's Avatar
I can't imagine why you wouldn't want a permanently mounted auto/manual bilge pump on your boat. What possible reason could there be to remove the pump when you go sailing?
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is offline
post #4 of 15 Old 01-04-2016
Just to understand, you want an automatic bilge pump that will evacuate water, when you're not at your boat, but not while you're aboard? Why not just a permanent install? A temp bilge pump still needs someplace for the discharge hose to go. Were you planning to route something temporarily up and over the gunnel? If so, a bilge pump's effectiveness declines with every foot of rise to the discharge. It would be much better to install it properly. Are you concerned about drilling a hole in your boat or doing the wiring?
Jeanneau 54DS
Minnewaska is offline
post #5 of 15 Old 01-04-2016
Sailor
Gladrags1's Avatar
Originally Posted by wrwakefield View Post
Rc,
Cheers!
Bill
SV Denali Rose
I second the recommendation for the Whale Supersub pump. It will pump the water up several feet as well to clear the gunnel as necessary.
Tod
Sent from my iPhone using Tapatalk
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #6 of 15 Old 01-04-2016 Thread Starter
I plan on running the output hose through the companionway hatch and out of one of the bailing ports in the cockpit.
This is really just a personal preference. I am not a fan of drilling into the boat nor do I think a normal bilge pump would be small enough to fit permanently.
I am going to check out the Whale Marine pump to see how that fits.
Rc26 is offline
post #7 of 15 Old 01-04-2016
Entirely your call, but isn't the companionway hatch going to allow water in?
Since all you want is a convenience pump, I would be very surprised there isn't a model you could secure to the bottom of the bilge. You could always just remove the hose, when you chose to.
However, making a hole in the topsides is pretty easy and there are plenty here that would help with placement and procedures.
Good luck.
Jeanneau 54DS
post #8 of 15 Old 01-04-2016
It's not automatic, but maybe you'd like a Whale GP1652 12v Hi-Flow Submersible Pump?
Whale GP1652 Pump Hi-Flow Submersible 12v: Amazon.co.uk: Sports & Outdoors
Here's a video on it ->
drakeParagon is offline
post #9 of 15 Old 01-05-2016 Thread Starter
Good luck.
Technically, yes but I also drape a plastic tarp over the hatch as well. (And the rest of the boat to protect from the sun)
I am open to all options though. If there is a small enough, reliable, and permanent automatic pump option, I am all ears.
Rc26 is offline
post #10 of 15 Old 01-05-2016 Thread Starter
Here's a video on it -> Whale Submersible Water Pump 12V d.c. GP1652 - YouTube
Definitely an option. If I went that route I could put a timer on it on say, once a week for 1 minute. Any knowledge on harm caused by running dry?
Rc26 is offline
Attwood Automatic Bilge Pump Switch obelisk Gear & Maintenance 5 02-03-2014 08:15 PM
Best Automatic Bilge Pump for a 1987 CS30? HBBurlington Gear & Maintenance 2 07-09-2013 09:44 AM
Adding automatic bilge pump to manual bilge pump FirstCandC Gear & Maintenance 13 04-03-2013 08:59 AM
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 11:36 AM
Automatic Bilge Pump Won't Shut Off zoom555 Gear & Maintenance 5 07-06-2009 04:22 AM
