Diesel tank repaired on Gulf 32 - SailNet Community
 2Likes
post #1 of 14 Old 01-20-2016 Thread Starter
Break, curse, fix, repeat
bwindrope's Avatar
I finally had to face about the most dreaded task I would ever have to face on my entire boat, and that is a leaking fuel tank. I know this is a common and even unavoidable problem at some point in the life of an aluminum tank, and so I did a full write up on my blog with photos. In it I tell the full tale of chambers, baffles, jigsaws, dremels, and Flamemaster 3204B2. Anyone facing this sort of project may benefit from my struggles, mistakes, and ultimate triumph.
Stories of Aeolus- Our Gulf 32 Pilothouse: Fuel tank repaired in epic fashion
May your boat stay on the water, the water out of your boat, your people on the boat, and your fuel in your tank!!
jrd22 and Faster like this.
Aeolus
Gulf 32
Bainbridge Island, WA
bwindrope is offline
post #2 of 14 Old 01-20-2016
Bleemus's Avatar
Re: Diesel tank repaired on Gulf 32
That is the kind of job that would have me cussing a blue streak. Well done.
Sent from my iPad using Tapatalk
Keth
Boat Vinyl Lettering and Graphics
Bleemus is online now
post #3 of 14 Old 01-20-2016 Thread Starter
bwindrope's Avatar
My language went right up the spectrum from red, orange, yellow, green, blue and into indigo and violet. It has proven useful to me to have had a father from Arkansas, who inadvertently taught me the finer aspects of Southern cussing. A true art form.
post #4 of 14 Old 01-20-2016
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Looks like a good project. I'm in the same situation. Keel mounted fuel tank, filled it up for the first time to find it leaking (then pumped out), and now in need of fixing/replacing it. My tank is mounted right under the engine so I pulled the engine and found a lot of issues with that so doing a bit of rebuilding on the engine too.
Good work on your fix. Hope the rest of the tank holds up.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #5 of 14 Old 01-21-2016 Thread Starter
bwindrope's Avatar
Rhapsody, good luck with it all. As I touch on in my blog, the decision to repair the tank in situ was driven by the cost and horror of trying to remove it and install a new one. If an easier option, I would consider replacement. Although, having said that, I feel my tank is now absolutely as good as new, and even better because I have access hatches fore and aft and middle. The new aluminum plate I put into the bottom is thicker than the original tank, and the Flamemaster sealant will last practically indefinitely.
As much of a PIA as it was, it is enormously satisfying and reassuring to have it done. To no longer have to worry about any crud in my tank, and to not have any diesel smell, or overflow, is all quite wonderful.
Aeolus
Gulf 32
post #6 of 14 Old 01-22-2016
Courtney the Dancer
jrd22's Avatar
Well done, a nasty job for sure. Glad it ended well.
I'm just getting ready to try and pull our starboard tank (95 gal. SS) out for repairs or replacement. I think I'm going to lack 1-2" of needed room to do so, which will entail some serious decisions to be made. I've successfully put this job off for two years now, but it hasn't fixed itself so I guess it's time.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
The Following User Says Thank You to jrd22 For This Useful Post:
bwindrope (01-22-2016)
post #7 of 14 Old 01-22-2016 Thread Starter
bwindrope's Avatar
jrd22, I waited several years hoping mine would fix itself too, but the boat gremlins never got around to it. That 1-2" you talk about can be a really serious PIA. If I was still in Friday Harbor I would try and swing by to see your process. Good luck.
Aeolus
Gulf 32
post #8 of 14 Old 01-23-2016
A friend of mine with a Leaky Teaky Taiwan Trawler had iron tanks go out on him.. he had to zipcut the old out in pieces, (after removing the engine - no small job) and then had new tanks made that he shoehorned into place.. but the only way that was going to work was with tanks 30% smaller - so he lost quite a bit of range.
Faster is offline
post #9 of 14 Old 01-25-2016
Cruiser
wrwakefield's Avatar
Hey John,
The previous owners of our boat replaced one of two 130 gallon fuel tanks before we bought the boat.
They ended up cutting the top off of the stbd iron tank; cleaning and patching the leaks; lining it with astroturf like carpet; and having two new tanks fabricated [access constraints] that nested nicely inside the old tank- which now acts as a temporary fail-safe if [when?] the new tanks leak.
The two new tanks were connected together on facing sides near the bottom with 1.5" fuel hose, so they behave as one baffled tank but with about 18 inches of space between them- which is now used for less than convenient storage...
The replacement tanks only have a total capacity of 86 gallons, but the savings in labor and demolitions was worth the net loss of capacity according to the POs.
I have all their detailed, annotated photos if this approach is of interest.
Best wishes with your project.
Cheers!
Bill
wrwakefield is offline
post #10 of 14 Old 01-25-2016
Broad Reachin'
kwaltersmi's Avatar
Nice work and good, helpful blog post. I replaced our leaking diesel tank last summer, but fortunately it wasn't all that hard since access was easy and the OEM part manufacturer is still in business.
Catalina 34
kwaltersmi is offline
If the diesel tank is done for... chartscharts Diesel 21 08-20-2015 04:22 AM
Smallish diesel tank Skipper Joe Diesel 1 08-10-2010 11:13 AM
Ever repaired a stainless water tank? JVallely Gear & Maintenance 9 11-29-2009 12:51 AM
Converting water tank to diesel tank - fittings? Zanshin Gear & Maintenance 5 09-15-2009 06:38 AM
New Diesel Tank Recommendations stevemac00 Pacific Seacraft 19 03-15-2009 04:06 AM
