Headsail sheets - SailNet Community
 12Likes
post #1 of 31 Old 02-22-2016 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
Headsail sheets
After you are done sailing for the day, do you coil up your sheets and store them at the bow pulpit to keep them from laying on the deck getting stepped on and gathering dirt? Do you worry that the headsail might unwrap itself in heavy winds?
brokesailor is offline
post #2 of 31 Old 02-22-2016
Re: Headsail sheets
No.
In 3 hurricanes and one tropical storm, the only damage to boats I've seen at my marina was due to peoples' headsails unrolling and flogging themselves to shreds. When you roll up the jib, be sure you keep a little tension on the sheet while you're rolling it up, to ensure that the roll will be tight. Cleat the furling line properly. I have seen many experienced sailors who either don't know how to properly cleat a line, or who don't bother. Sometimes they just throw a loose cleat hitch on it. If you expect a major storm, either strip off the sail, or at least wrap an extra halyard around it in a spiral the opposite way from the way it's furled, to prevent the wind from tugging an edge loose. If I've done those things, then I don't worry about it.
BarryL and oysterman23 like this.
Sailormon6 is online now
post #3 of 31 Old 02-22-2016
Crealock 37
sailak's Avatar
Dock
Re: Headsail sheets
I do not store them at the bow. I leave the sheets rigged, coiled and hung from the lifeline at the cockpit.
I do that to keep better tension on the sheet to prevent wind from unfurling the sail.
brokesailor and MedSailor like this.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #4 of 31 Old 02-22-2016
outbound's Avatar
Another thing I see are those Flemish cute spirals made from tails. They lie flat so collect dirt and water doesn't drain. Better to make figure 8s or get the twist out and just dump the line. Ugly but better for that expensive line.
outbound is online now
post #5 of 31 Old 02-22-2016
Tanski's Avatar
Re: Headsail sheets
For me it depends on how long the boat will be sitting, anything more than a few days they come off and the cover gets hoisted over the headsail. IF it was going to be a few weeks I'd completely remove the sails, mostly because of spiders. Spider crap is nasty stuff to get off sails.
Tanski is offline
post #6 of 31 Old 02-22-2016
Re: Headsail sheets
... and those nice tidy 'coils' are, coincidentally, considered to be ideal 'toilets' by any otters that may hang around your dock. Perfect little piles nicely centered
We take several turns around the furled jib, then add enough tension against the cleated furling line to keep the sheets off the deck. Our sheet length is such that there's no real 'tail' leftover to worry about at that point.
For the serious offseason we take the jib off the furler and store sheets below. If we get lucky enough to get away, we'll rig the boat to go, then de rig the headsail again at the end of the day.
March thru October we leave her ready to rumble..
Faster is offline
post #7 of 31 Old 02-22-2016
FSMike's Avatar
Re: Headsail sheets
We put a couple of turns of line around the furled jib and leave the sheets tensioned on the self tailing winches. I've seen a number of furling jibs shredded when left with a piece of sail exposed enough to be caught by a squall.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #8 of 31 Old 02-22-2016
BarryL's Avatar
Re: Headsail sheets
Hey,
As others have mentioned I leave the sheets run back to the cockpit (snugged up on the self tailing winches). I also tie a small line around the furled headsail so that even if the furling like breaks the sail can't unroll.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is online now
post #9 of 31 Old 02-22-2016
Re: Headsail sheets
Had some 50 kts. winds here a couple weeks ago and there must have been a dozen sails shredded, a friend sent me a photo of a Catalina 309 that was sitting broadside to the winds and it shredded the headsail AND the inmast main. People get REAL complacent about the weather in San Diego.
I coil the sheets on the bow pulpit when away from the boat for more than a day, besides measures others have mentioned I've recently started using a jib sleeve from ATN that also prevents unfurling.
"Just call me TB"
capttb is offline
post #10 of 31 Old 02-22-2016
Re: Headsail sheets
"I have seen many experienced sailors who either don't know how to properly cleat a line, or who don't bother. Sometimes they just throw a loose cleat hitch on it."
What is the proper way to cleat a line? I thought it was by tying a cleat hitch?
MarkSF is offline
Need a headsail..what to go with? Shortnsalty General Discussion (sailing related) 6 04-15-2014 04:33 PM
New headsail PaulinVictoria Gear & Maintenance 27 12-28-2013 03:30 PM
Name this headsail jjablonowski Seamanship & Navigation 7 05-19-2011 03:15 AM
converting a furling headsail to a hanked on headsail mrkeith Gear & Maintenance 6 02-15-2007 03:36 PM
How much can you furl a headsail swg Seamanship & Navigation 9 05-02-2002 10:04 PM
