Anchor solution - SailNet Community
 2Likes
  • 1 Post By DonScribner
  • 1 Post By fallard
post #1 of 10 Old 04-10-2016 Thread Starter
Deep Blue Crush
paikea's Avatar
Anchor solution
Hi ,
My boat is going through the spring projects, some refitting, few additional "cosmetics", full cleaning etc.
One of them is the anchor, I am not comfortable with the anchor system.
The pictures will be self explanatory.
I am not sure why the previous owner decided on this system.
Tip of the bow, he cut it open with the vberth.
On top of the usual place where the chain should go, a large bollard (I think thats the name) is attached, half on the hatch, have on the deck.
The anchor chain sits in a box on the deck, that seem to me a safety hazard and really not practical at all.
I want to get the system back as it should be, as I have seen on other boats I sailed.
1. Redo the little wall separating the vberth area from the tip of the bow.
2. Move the bollard towards the mast a little, so that I can open the hatch and redo that with proper hinges and closing system.
3. Get the chain to stay there full time.
Any reason why these cant be done? shouldnt be done?
Another idea?
Deep Blue Crush
paikea is offline
post #2 of 10 Old 04-10-2016
Re: Anchor solution
It looks to me that the PO was looking at storage space inside. It probably made perfect sense to him at the time and truly solved a problem, otherwise he wouldn't have invested so much time, and money, into it. From my point of view, and I believe yours as well, this solution is, in a word, numb. Funny part is, this is the way my Lancer is set up; a storage area in the bow where the anchor locker should be. I keep my rode wound around the same plastic spool that is came on and stuff it back into that storage spot when not in use. Its a pain in the transom but mainly when stowing the anchor. To "fix it" I'd do as you intend, but keep in mind that when that hatch becomes operational, you now have a great spot for water to enter. The watertight anchor locker liner looks to be removed. Looks like you'll need a couple of horn cleats too.
What a tangled mess they make, when clueless hands doth renovate.
oysterman23 likes this.
DonScribner is offline
The Following User Says Thank You to DonScribner For This Useful Post:
paikea (04-10-2016)
post #3 of 10 Old 04-10-2016 Thread Starter
Deep Blue Crush
paikea's Avatar
Re: Anchor solution
Thank you Don.
Truth be told, I am clueless too, but common sense is common sense. My womanly hands wont try to attempt to fix this totally alone. I will surely end up doing something probably even dumber.
I want to know what direction I go and then I will get someone to help me so that I get it done and learn too.
The anchor locker area will indeed have the water issue. How is that fixed usually so that water doesnt just stays in there, its impossible that it wont get in, in a rainy day, or a more choppy water, even if its a little, not good for the chain. I did handle a very rusted chain once and that was really bad. Are there some sort of "holes" made at the bottom of the locker?
I know everyone is very much into "no holes the hull", but there must be a way to overcome the water stagnating there.
Deep Blue Crush
paikea is offline
post #4 of 10 Old 04-10-2016
Re: Anchor solution
We had a similar situation on our last boat.. and opening in the forward bulkhead and just a small deck hawse fitting for the rode. In addition, the forepeak drained to the bilge.
We added a floor (Fiberglassed into the triangle of the bow at an appropriate height, sloping down towards the stem) and drilled a drain hole through the stem. The floor had a 3 inch curb aft to ensure any stray water couldn't find it's way into the boat. We then added a tight fitting dropboard onto the forward face of the bulkhead. We also had to cut the deck lid out of the exisiting deck, you won't need to do that, just 'free' the original and restore it.
We then covered the bulkhead cutout with another (nice, varnished) drop board on the aft face. This cleaned up the area and allowed us to maintain access from below if we needed it. The system looked and worked fine. Hopefully this sketch will help imagine it.
If you open the deck up first, you can add the floor from above, and seal the bulkhead opening entirely, then all you need is the decorative cover board for the hole in the bulkhead in the V berth area
Faster is offline
The Following User Says Thank You to Faster For This Useful Post:
paikea (04-10-2016)
post #5 of 10 Old 04-10-2016 Thread Starter
Deep Blue Crush
paikea's Avatar
Re: Anchor solution
@Faster
Thats very helpful indeed, thank you!
There is a man at the marina, he built his own 48 feet boat with a double hull (double hull wall fiberglass and wood (?)) , looking at his boat, I think I can trust his skills enough that he can help me to actually do this, as in literally doing it.
Deep Blue Crush
paikea is offline
post #6 of 10 Old 04-10-2016
travlin-easy's Avatar
Re: Anchor solution
My anchor locker drains into the bilge via a length of 1/2-inch PVC pipe at the base of the locker that leads to the forward portion of the bilge beneath the vee berth. Never had a problem.
Good luck,
Gary
travlin-easy is offline
The Following User Says Thank You to travlin-easy For This Useful Post:
paikea (04-11-2016)
post #7 of 10 Old 04-10-2016
fallard's Avatar
Re: Anchor solution
My anchor locker is configured as Faster shows his. One advantage of the sloped floor that drains forward through a hole is that you will keep smelly stuff (mud and the things that live in mud) away from your bilge. (Gary-travlineasy- has a wash down for his anchor chain, so he probably doesn't have an issue with mud in his bilge.)
My 1/2" drain hole is shown in the thumbnail at about 15" or so above the waterline. I've never had a problem with water coming in that hole; maybe because it is so small. Nonetheless, it is an effective--but slow--drain and hasn't clogged.
Also, you might notch out the forward tip of your newly liberated hatch to act as a hawse pipe for your chain. Then you might replace your "bollard" with a cleat off the the side to tie off your anchor rode.
Good luck with this--it isn't that hard to fix.
Faster likes this.
fallard is online now
post #8 of 10 Old 04-10-2016
al brazzi
Re: Anchor solution
What was the original configuration, there looks to be a removable triangular piece in front of the Samson post, (which is a nice one by the way) an it doesn't look big enough to get an anchor in it, the anchor was probably stored on the nose anyway. I see it is now. It looks like he opened that area up to properly reinforce the mount and that is where the hawse pipe would have been. Maybe just add a hawse pipe so the chain and rode can go in the compartment then as Faster said put a floor if there's not one there. Every Boat I have owned has a proper anchor storage area with a hinged lid and a drain I wouldn't want it open to the bilge. Maybe the lid by design needs a draining floor so if the lid is blown up in a blow you don't take on water. One more point if the removable section is (was) there to clear any tangles in the anchor line, then the opening needs to still be there through the Vee but it can have a nice cover with a few screws in it. I'm with you I wouldn't wand that plastic box on the bow like that, I'm amazed the things people think is OK on a cruiser.
albrazzi is offline
post #9 of 10 Old 04-10-2016
Re: Anchor solution
I'd definitely recommission the original opening anchor locker lid rather than go to a hawse pipe type of set up. They are simply too slow and awkward when stowing the rode on retrieval.
The Friendship 28 was set up with a good locker from the factory (at least at deck level) so the OP is half way there already.
The Samson post (yes, a nice one) seems a bit of overkill to me, but could be moved a bit if keeping it is desired.
Faster is offline
post #10 of 10 Old 04-10-2016
Re: Anchor solution
Fallard, you're right about the washdown - the slimy, gooey, stinky mud on the bottom of Chesapeake Bay sticks like glue to the anchor and chain and without the washdown the anchor locker would be a disaster. Love my washdown system, and it's great for when I scrub down the boat and I'm anchored up in some remote cove.
All the best,
Gary
Need a creative solution rbyham Gear & Maintenance 16 03-28-2014 07:18 PM
anchor and boat design ? Why anchor the bow. Lou452 General Discussion (sailing related) 19 01-26-2014 08:05 PM
Anchor alarm for android phones - Anchor Alert Bene505 Electronics 28 04-29-2011 05:31 PM
best GPS solution? jjrunning Gear & Maintenance 26 02-20-2010 06:19 AM
Yet another anchor question. Has anyone seen/used an Oceane anchor? SVDistantStar Gear & Maintenance 2 08-28-2008 01:09 AM
