Inverter problem and an unlikely fix - SailNet Community
post #1 of 11 Old 04-20-2016 Thread Starter
After I uncorked the boat this year, I noticed that the Xantrex freedom 10 charger/inverter console wasn't working right. It wasn't showing correct information, claiming that it was in bulk charge mode when, in fact, the batteries were fully charged. Then it stopped working entirely.
I consulted with a friend who used to repair such things for a living. He told me that before I converted the unit into a spare anchor he suggested I remove it, disassemble and reassemble the electronics.
Last weekend, I did this, thinking he was crazy. Much to my surprise, it worked, and the inverter is now functioning perfectly again.
It took a couple of hours to remove the damn thing, but reseating the electronics took all of about 5 minutes. Apparently if you sail enough, things like that get loose, and it lowers the voltage just enough to make the electronics go weird or stop working.
Seeing as I work with electronics for a living, this has taught me that a marine environment causes all sorts of electronics issues you just don't see on land.
Captain Canuck is online now
post #2 of 11 Old 04-20-2016
Chastened
Ajax_MD's Avatar
Re: Inverter problem and an unlikely fix
May I ask how large your inverter is, and what you power with it?
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #3 of 11 Old 04-20-2016
If you put some No-Ox-Id on the contacts before re-assembly, it'll prevent future problems.
IStream is offline
post #4 of 11 Old 04-20-2016 Thread Starter
It's a 1000W inverter. It's for the microwave in the galley, which we never use anyway. Both the microwave and the inverter are original equipment with the boat.
Honestly, if it wasn't also the battery charger (and a very good one at that) I wouldn't have bothered fixing it.
post #5 of 11 Old 04-20-2016 Thread Starter
I'll keep that in mind if this happen again. Hopefully not before I sell the boat.
post #6 of 11 Old 04-20-2016
Chastened
Ajax_MD's Avatar
Ok, just curious.
Over the years, I read about a lot of problems with these things, and I always wonder what shore side appliances people can't do without, that requires an inverter. Your circumstances make more sense.
I've installed a 750w GENERAC standalone inverter, tied directly to the house battery. It has its own 110v outlets and a USB port and does *not* tie to the boat's AC system. I use it for rapid charging of cell phones, iThings and occasional power tool use (shop vac, drill, etc)
I have a separate, Guest smart battery charger.
Ajax_MD is offline
post #7 of 11 Old 04-20-2016
Old enough to know better
Yes, and therefor the phrase "friends don't let friends buy Xantrex"
But if you did not re-solder the joints it will likely happen again very quickly.
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #8 of 11 Old 04-20-2016
Omatako's Avatar
Hmmmmm. . . Interesting.
I have a Xantrex inverter (2500w) and a Xantrex Link 20 battery monitor in the boat and what I think is a kick-ass Xantrex battery charger which is now at home (no longer have shore power on the boat). All three have worked exactly as the manufacturer said they would and never a single glitch at any time in the ten years I've owned them.
You must have had a different experience that prompts your phrase? Maybe there is something I need to know.
Arthur C. Clarke
Omatako is offline
post #9 of 11 Old 04-20-2016 Thread Starter
The cables weren't soldered. There was a single cable connection that looked like it was hot glued, but other than that they were standard multi-pin connections as exist in any other piece of electronics I've worked with. The connections seemed ok, but pulling and reseating them probably broke some oxidation on the connections.
post #10 of 11 Old 04-21-2016
I mentioned all the surface mount components. Likly some dry solder joints, or even iffy capacitors.
Xantrax issue is mostly the support or lack of it. They do seem to buy some good electronic designs though.
Sent from my Nexus 6 using Tapatalk
1976 C&C 33
inverter vs inverter / charger BarryL Gear & Maintenance 24 03-30-2014 04:56 PM
Freedom 2000 inverter/charger problem stubby1234 Electrical Systems 3 03-24-2013 08:25 PM
Inverter SayGudday Electrical Systems 0 12-26-2012 10:56 PM
FYI: To all owners of Yanmar Diesels -YSM8 -found fix to stall problem jrowan Diesel 2 04-14-2010 08:37 AM
Inverter Problem dsbentley Gear & Maintenance 3 01-07-2007 02:55 PM
