Oops...I think I stripped some gelcoat - SailNet Community
 5Likes
  • 1 Post By hellosailor
  • 1 Post By Sailormon6
  • 3 Post By RobGallagher
post #1 of 10 Old 04-23-2016 Thread Starter
Minnesail's Avatar
The previous owner put a barrier coat on my transom-hung rudder and was very sloppy about it, splashing a lot well above the water line. I wanted to clean it up a bit so I masked off a line about 2" above the waterline and put some citrus based paint stripper on. When I scraped it off it didn't do that great a job taking off the paint, but it sure seemed to take off the gelcoat...
So...what do I do? I'm only moderately worried about aesthetics. I have West System epoxy on hand, can I just spread some epoxy over the damaged area? Some sort of paint?
Thanks in advance.
I'm attaching two pictures, one is closeup with harsh side-lighting to emphasize the texture.
Catalina 22
on a starboard tack
Minnesail is offline
post #2 of 10 Old 04-23-2016
Irrationally Exuberant
Re: Oops...I think I stripped some gelcoat
Are you saying it took off the barrier coat--which is paint-- or the actual gelcoat?
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #3 of 10 Old 04-23-2016
It's always hard to tell from a photo, but it looks like you used a chemical stripper that was made to strip house paint, or something other than paint on a gelcoated fiberglass boat. Those ordinary paint strippers are much too aggressive and can dissolve gelcoat. I did that once over a small area.
You still have to remove old paint and barrier coat. There are chemical paint strippers that will do that without damaging any more gelcoat. I would suggest you google "paint stripper for gelcoated fiberglass" and you'll get products and advice for DIYers. After you strip away all the old materials, then you have to replace the dissolved gelcoat, to smooth the surface again. You can do that with epoxy, or other available marine underwater fillers.
Sailormon6 is online now
post #4 of 10 Old 04-23-2016 Thread Starter
Minnesail's Avatar
Doh! The actual gelcoat. I edited my post so it now says what I actually meant.
Like this?
BACK TO NATURE
Marine Paint Remover
Then once the rest of the paint is off I could seal it with some West System epoxy? That will stick to whatever Catalina used to build up the rudder?
Catalina 22
on a starboard tack
The Following User Says Thank You to Minnesail For This Useful Post:
timangiel (04-23-2016)
post #5 of 10 Old 04-23-2016
Minne-
I've had that same "safe organic" orange creamy stuff take the coating off all sorts of things that I least expected. Welcome to the club.
Depending on your aesthetics and free time? I'd use white marintex first. Fill in the damage, sand it down (covering with some "Teflon" or mold release will help get it smooth) and see how bad it still looks. If it doesn't match well enough to ignore, the "guaranteed" cure is probably to just bite the bullet and repaint the transom. Take the opportunity to move any fittings and repaint the name and hailing port exactly as you want.
PITA, but it beats repainting a hull side, right?
Minnesail likes this.
hellosailor is offline
post #6 of 10 Old 04-26-2016
Originally Posted by Minnesail View Post
I haven't used that product, so can't say. When it comes to chemical paint strippers, don't be too put off by negative reviews that complain that it doesn't work very well. Many people don't understand that it takes time for them to break down the old paint. I recommend putting on 2-3 applications, or more, and give each application time to work before trying to scrape it off. If you aren't patient, you'll find that it will only soften one or two layers of old paint, but the layers beneath will still be adhering.
You could, but, like hellosailor, I have had good success with Marinetex.
oysterman23 likes this.
post #7 of 10 Old 04-26-2016
HANUMAN
RobGallagher's Avatar
Second the West System.
Every stripper I've tried has broken my heart. To harsh or don't do as promised and there is always a big mess in the end. Now I do it the old fashioned way, by hand.
miatapaul, Adele-H and Minnesail like this.
WINDHOVER
1999 CATALINA 36 MKII
NOANK, CT
RobGallagher is online now
post #8 of 10 Old 04-27-2016 Thread Starter
Minnesail's Avatar
The instructions say
Hints: Let the stripper work for you.
Well that just makes sense.
Then it gets weird
Give the stripper proper time to penetrate.
Maybe I got the wrong kind of stripper...
Catalina 22
on a starboard tack
post #9 of 10 Old 04-27-2016
HANUMAN
Ever been to Phuket?
https://youtu.be/x0bC__I-Lqs
WINDHOVER
NOANK, CT
post #10 of 10 Old 04-28-2016
outbound's Avatar
Had petit spray cans on the underwater metals. Wanted to convert to Velox plus. Required bare metal so tried several different types of safe for fiberglass chemical strippers. All were totally ineffective. Maybe too cold here or I didn't wait long enough but none had any effect at all.
Ended up sanding which was very time consuming as many spots were inaccessible to even a dremel. Did hit the barrier coat in some small areas (a few inches) with power tools before biting bullet and going to just hand sanding. Wanted adequate thickness of barrier and a smoother fairing at junction of metal to glass. Used the two part Interlux 2000e product. Found you could modify with 2333n. So used it straight to build up thickness, sanded, then again a coat, sanded, then thinned. Step off between strut and hull gone. Good barrier coat every where. Holds paint well.
So if your areas are not too deep may want to go with that product. That way you can go with just one product. Can get it real smooth for a good cosmetic result. Depending on color and what you want may even get away with not painting over it.
s/v Hippocampus
Outbound 46
outbound is online now
Stripped Transmission Dipstick night0wl Diesel 16 02-17-2019 10:19 PM
Stripped gooseneck threads eko_eko Gear & Maintenance 25 04-05-2016 11:10 PM
2GM15 Stripped out bolt ltgoshen Gear & Maintenance 9 08-05-2013 03:13 PM
Banjo Bolt Stripped? T37Chef Gear & Maintenance 2 07-11-2008 01:03 AM
Stripped screw hole sklamar Gear & Maintenance 3 05-30-2002 07:10 PM
